Internal Oscillator setup for the 18F4525
PostPosted: Fri Dec 29, 2006 12:34 pm     Reply with quote
What is the correct method of setting up the 18f4525 internal oscillator? This is what I have so far:
#include <18f4525.h>
#use delay(internal=8M)
#fuses NOWDT, NOLVP, NOPROTECT, NOPUT, NOBROWNOUT
//setup_oscillator(OSC_8MHZ); <-- the manual says that I don't need this line if I have the fuses command set to internal oscillator. Is the #use delay command enough? If not, what is the fuses command that I need?
PostPosted: Fri Dec 29, 2006 1:48 pm     Reply with quote
Try the test program shown in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=28833
Note that the INTRC_IO fuse is used. Also note that the #use delay
statement is placed after the #fuses statement.
