CCS CANBus Dev board problems
TL
PostPosted: Thu Dec 28, 2006 4:16 pm     Reply with quote
I'm having 2 problems on this board. Any comments would be appreciated. Thanks.
1. In section 7, I can get the 7-segment to display 0 to 9 in turn with no problems, but cannot get the decimal point to light up for the 7-segment display. Here is the code:
#include <18F4580.h>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#include <can-18xxx8.c>
#define WRITE_REGISTER_D_ID  0x400  // Address of Node D.
// This program turns ON the decimal point in the 7 segment display on Node D.
void write_7_segment(int value) {
    const int lcd_seg[10]={0x40,0x79,0x24,0x30,0x19,
                           0x12,0x02,0x78,0x00,0x10};
    int buffer[3];
    buffer[0]=0x1E;      //addr of gplat = (0x1C + 0x02) where 0x1C is an offset address in MCP25050.
    buffer[1]=0x80;      //mask, Allow GP7 (decimal point) on MCP25050 to be changed.
    buffer[2]=0x00;      //Enable decimal point by setting bit 7 to logic 0.
    // Write to 0x400 (Node D), with buffer of 3 bytes, priority=1, 29bitID, and data frame
    can_putd(WRITE_REGISTER_D_ID, buffer, 3, 1, TRUE, FALSE);
   int i=0;
   can_init();
   can_putd(0x100,0,0,1,TRUE,FALSE);  //send an on-bus message to wake up mcp250x0's
   delay_ms(1000);                    //wait for node c to power-up
   while(TRUE) {
       write_7_segment(i);
       if(++i==10)
          i=0;
I have isolated the MCP25050 from the 7-segment chip, and found that all the LED segments were working including the decimal point (DP) by performing the diode test in both directions. However, with the above program running, the voltage on GP7 (pin 11 of MCP25050) which is connected to the cathode of the DP via a 120R resistor was about 3.7V. Ideally, this should be about 0V to turn on the DP.
Has anyone got the DP to work, or is there a problem on the MCP25050?
2. In section 18, I cannot get the auto-RTR to work. Here is the code:
Node A:
//#device ICD=TRUE
#include <can-18F4580.c>
   int32 rx_id;
   int rx_len, i;
   struct rx_stat stat;
   int data[8]={15,14,13,12,11,10,9,8};
   int receive[8];
   can_init();
   can_set_functional_mode(1);
   can_enable_b_transfer(B1);
   can_disable_filter(0xFFFF);
   can_enable_filter(0x01);
   can_set_id(RX0MASK,0xFF00,TRUE);
   can_set_id(RXFILTER0,0x500,TRUE);
   can_set_id(B1ID,0x500,TRUE);
   can_associate_filter_to_mask(ACCEPTANCE_MASK_0,F0BP);
   can_associate_filter_to_buffer(AB1,F0BP);
   can_load_rtr(B1,data,8);
   can_enable_rtr(B1);
   while(TRUE);
Node B:
#include <16F876A.h>
//#device ICD=TRUE
#use delay(clock=2500000)
#include <can-mcp2510.c>
   int32 rx_id=0;
   int rx_len=0, i;
   int data[8]={7,6,5,4,3,2,1,0};
   int receive[8]={0,0,0,0,0,0,0,0};
   can_init();
      can_putd(0x500,data,8,3,TRUE,TRUE);
      if ( can_kbhit() )
          can_getd(rx_id, receive, rx_len, stat);
          printf("Data received!\n\r");
          for(i=0; i<8; i++)
             printf("%i ",receive[i]);
          printf("\n\r%Lx\n\r",rx_id);
          printf("Data not received.\n\r");
All I got from Node B was the following:
Data received!
0 0 0 0 0 0 0 0
00000500
and repeats...
The 'receive' buffer is all 0's, and rx_len is also 0. The can_kbhit() function returned a 1. The ID received is correct at 0x500.
Ideally, it should be the following (according to the exercise book):
Data received!
15 14 13 12 11 10 9 8
00000500
and repeats...
