RF controlled mobil robots axis movement problem
rnome
PostPosted: Mon Dec 25, 2006 4:17 am     Reply with quote
hi everybody
i have great problem about a rf controlled mobile robots' axis movement. i m using a anolog joystic for sensetive control and robot have two dc motors that it ll move as a tank. for each axis (x-y) movement i must use different pwm values and in this case i need to control 242 different pwm values.
i dont know how to control this pwms effectively
i ll use pic16f877 at 4mhz crystal
live fast, never rest and do your best
Neutone
PostPosted: Mon Dec 25, 2006 11:25 am     Reply with quote
I would solve this with a formula. I would interpret the movement as y axis being forward/reverse and the x axis as turn left/right.
signed int8 y_Movement
signed int8 x_Movement
signed int16 M1
signed int16 M2
y_Movement = y_Joystick+128
x_Movement = x_Joystick+128
M1=y_Movement
M2=y_Movement
if x_Movement>0
{ M1=M1-x_Movement
{ M2=M2+x_Movement
Then scale up to 242
M1=242*M1/128
M2=242*M2/128
rnome
PostPosted: Tue Dec 26, 2006 7:21 pm     Reply with quote
thanks neutone for your effort
i solved this problem with a less sensetive way before nearly madness:)
void cmp(int x, int y)
int pwm_x,pwm_y;
if(y>=150){ //forward
pwm_y=(y-125)*2;
motorsur_ileri();
if(x>=150) //forward and right
pwm_x=pwm_y/2;
if(x<=100){ //iforward and left
pwm_x=pwm_y;
pwm_y=pwm_y/2;
if(x<150>100) //only forward
pwm_x=pwm_y;
if(y>100&&y<150>=150){ //only right
pwm_y=100;
pwm_x=0;
if(x<=100){ //only left
pwm_y=0;
pwm_x=100;
if(x<150>100){ //stop
pwm_y=0;
pwm_x=0;
if(y<100>=150) //reverse and right
pwm_x=pwm_y/2;
if(x<150>100) //only reverse
pwm_x=pwm_y;
if(x<=100){ //reverse and left
pwm_x=pwm_y;
pwm_y=pwm_y/2;
set_pwm1_duty(pwm_y);
set_pwm2_duty(pwm_x);
