I2C issue
pr83
I2C issue
PostPosted: Sun Dec 24, 2006 10:20 am     Reply with quote
I had a couple of questions.
I am trying to implement I2C interface between a master and slave device.
1. I see there are pull up resistors connected to the SDA and SCL line of both the device(Master and Slave). Is that an issue, and what will I need to do?
2. I get some values in the slave device from its 10 bit ADC. I have been multiplying that number to an ADCfactor = (5/(2^(10))). But instead of doing this I want to take that number coming out of the 10 bit ADC and send it to the Master in 2 write commands so it could be packed into a 16 bit value. How do I take that number and convert into a bunch of 0s and 1s as a 16 bit packet. I also have some instances when I need to convert that number coming out of the ADC in the slave as just an 8 bit number and send it to the Master through just 1 write command. What will I need to for that.
PostPosted: Sun Dec 24, 2006 12:18 pm     Reply with quote
What are the resistor values ? For a 5v i2c bus, the lower limit for
the pull-ups is about 1.6K. If you have two pullup resistors, use the
"product over sum" formula to find the effective resistance.
Example:
One side has 4.7K. The other side has 3.3K.
 4.7 x 3.3       15.51
------------ =  ------- = 1.94
 4.7 + 3.3        8.0
The combined resistance is 1.94K, and this is greater than the 1.6K
minimum, so it's OK.
pr83
PostPosted: Sun Dec 24, 2006 4:09 pm     Reply with quote
Thank you PCM Programmer. You are correct I can treat them as Rs in Parallel.
