ADC Help Please
Abe
ADC Help Please
PostPosted: Sat Dec 23, 2006 5:02 pm     Reply with quote
Hi I am very new at PIC programming and am becoming very frustrated.
Can anyone help me set up an Analog to Digital Conversion? I have a Picdem 2 Plus demo board and would like to program the POT on RA0 to read the input and output the value in a digital fashion.
I have set #device ADC=10 in the C file just after #include<16F877A.h>
#use standard_io(D)
int 16 a, b, c, d, e;
int 16 value;
VOID MAIN(VOID){
delay_ms(200);
tris_portd = 0x00;
SETUP_ADC_PORTS(RA0_ANALOG);
SETUP_ADC(ADC_CLOCK_DIV_32);
WHILE(1){
a = 205;
b = 410;
c = 615;
d = 820;
e = 1024;
set_adc_channel(0);
delay_us(20);
value = READ_ADC();
Then there are several IF statements so that LEDs can be lit up accordingly. Obviously alot of code is missing but I tried to include only the important ADC portions of the code. If anyone can tell me where I am going wrong or what I am missing I would sure be thankfull.
Thanks again, Abe
PostPosted: Sat Dec 23, 2006 5:32 pm     Reply with quote
I don't see an obvious error in your program. You didn't give a complete program, neither did you tell us what isn't working so right now we can't help you any further.
Give us a small but complete program to test (and then please use the 'code' buttons for preserving the code layout).
Or you might have give the program ex_admm.c in the picc/example directory a try to see if that is working.
PostPosted: Sat Dec 23, 2006 6:36 pm     Reply with quote
Read my post near the end of the following thread. You'll find sample
code to use the ADC with the trimpot on the PicDem2-Plus board:
http://www.ccsinfo.com/forum/viewtopic.php?t=28842
