I2C Slave problem
MathewF
I2C Slave problem
PostPosted: Thu Dec 21, 2006 8:45 am     Reply with quote
i2c Slave Problem
I am using:
CCS Compiler PCM 4.013
Device PIC 16F819 as SLAVE
Device PIC 18F252 as MASTER
I am having trouble with the i2c i can not get the 819 to read or write anything to the master, I have the code working on some 18F2431.
I have pared the code down completly so it will just read or write one byte in response to 252 and stil get nothing.
On the 819, the poll command still works, the write comand does not write and the read command causes the clock pin to go low and stay low.
Can Anyone Help?
******                           SPEED INPUT PIC V0-3                              ******
******                                 21-12-06                                 ******
******                              Matthew Finch                                 ******
******                                Rosmore Ltd                                 ******
#include <16f819.h>         //Header file for the device
#ZERO_RAM               //Zeros all RAM at startup
#use Delay(Clock=20000000)   //sets up clock for any delay instructions
#Fuses HS,NOWDT,PUT,BROWNOUT,NOLVP,NOWRT,NOCPD,NOPROTECT,NODEBUG,CCPB3      //Sets up Configeration bits
//Constant definitions
#define SLAVE_ADDRESS 120      //I2C address for this chip
//file definitions
#include <Main Delay.c>      //Delay for Program Loop
#include <I2c(5).h>         //I2C Interrupt
//Variable definitions
output_low(PIN_B6);
output_float(PIN_B1);   //float i2c pins
output_float(PIN_B4);
Set_up_main_loop_timer();
Init_Setup_I2C();
enable_Interrupts(GLOBAL);
output_low(PIN_B2);      //low pins used for looking at program
output_low(PIN_B6);
output_low(PIN_B7);
   output_toggle(PIN_B5);
   Main_loop_timer();
      I2C    V5-0    21/12/06    Matthew Finch    Rosmore Ltd
Read/Write Commands down I2C lines
#USE I2C(SLAVE,SDA=PIN_B1,SCL=PIN_B4,ADDRESS=SLAVE_ADDRESS,FORCE_HW,FAST)
#BYTE SSPSTAT = 0x94
#BYTE SSPBUF = 0x13
#BYTE SSPCON = 0x14
//function definitions
void Init_Setup_I2C();
put in main section of program at the beginning (before program loop)
Setups up the I2C interupt
enable_interrupts(INT_SSP);
I2C Interupt
#INT_SSP
void i2c_interupt()
int a;
if(i2c_poll()==TRUE)         //reads in byte if one there
   a=i2c_read();
   //output_float(PIN_B4);
   i2c_write(7);
   output_toggle(PIN_B6);
rnielsen
PostPosted: Thu Dec 21, 2006 10:27 am     Reply with quote
First, don't do a poll() inside an ISR. If you have entered the ISR then something has happened to cause the interrupt. Instead of doing a poll(), check the SSPSTAT register and see what condition exists. Is the Master simply addressing the Slave? Is the Master trying to write a command or data to the Slave? Or, is the Master trying to read data out of the it? You need to find out what the Master is trying to do before the Slave can know how to respond. Next, don't do something like calling another function from an ISR. ISR's should be short and simple. If you want to read the ADC then set a bit and when the ISR exits have the main() loop read that bit and do your ADC stuff there. Lastly, that I saw, you don't need 'fast' in your #use_i2c fuse. The Master controls the speed of the clock.
Search the forum here. There is a boat load of posts regarding I2C communications and how to set things up.
Ronald
PostPosted: Thu Dec 21, 2006 11:52 am     Reply with quote
CCS has a function to do this. Look at I2C_ISR_STATE( ) in the manual.
