ps2
hadeelqasaimeh
ps2
PostPosted: Sun Dec 17, 2006 6:29 am     Reply with quote
hi all;
according to the following link:
http://www.ccsinfo.com/forum/viewtopic.php?t=25673&highlight=ps2
i try to use this new library,,when i add an lcd library "lcd_kbd1.c" its make an error!! while "lcd.c" don't!! why?
here is my lcd_kbd1 library:
#include <jonsinc.h>
// These defines are specifically for a 4x16 line display.
#define LINE_16_1          0x00
#define LINE_16_2          0x40
#define LINE_16_3          0x10
#define LINE_16_4          0x50
// These defines are specifically for a 4x20 line display.
#define LINE_20_1          0x00
#define LINE_20_2          0x40
#define LINE_20_3          0x14
#define LINE_20_4          0x54
// Another define for use in LCD_PutCmd
#define CLEAR_DISP      0x01
// This is a macro used in the subroutines below */
#define     PULSE_EN        EN = 1; delay_us ( 10 ); EN = 0; delay_ms ( 5 )
#byte   port_e  =   9           /* set variable that maps to memory */
#byte   PORT_A  =   5           /* set variable that maps to memory */
#byte   port_b=   6
#byte   PORT_D=   8
#byte   DATA = PORT_A
#bit    RS = port_e.0
#bit    EN = port_e.1
char kbd_getc(void);
char getkey ( void );
// These are prototype statements.
void LCD_SetPosition ( char cX );
void LCD_PutChar ( char cX );
void LCD_PutCmd ( char cX );
void LCD_Init ( void );
// These are the display subroutines.==============================
    // Initializing into 4-bit mode is a very exact sequence
    // as defined in the datasheets for these displays.
    set_tris_a ( 0x00 );        /* outputs */
    set_tris_b ( 0xFC );        /* Bits 0 & 1 are outputs */
    set_tris_e ( 0xF0 );
    DATA = 0x00;
    delay_ms ( 200 );       /* wait enough time after Vdd rise */
    RS =0;
    DATA = 0x03;            /* init with specific nibbles to start 4-bit mode */
    PULSE_EN;
    PULSE_EN;
    PULSE_EN;
    DATA = 0x02;            /* set 4-bit interface */
    PULSE_EN;               /* send dual nibbles hereafter, MSN first */
    LCD_PutCmd ( 0x2C );    /* function set (2 lines, 5x7 characters) */
    LCD_PutCmd ( 0x0E );    /* display ON, cursor on, no blink */
    LCD_PutCmd ( 0x01 );    /* clear display */
    LCD_PutCmd ( 0x06 );    /* entry mode set, increment */
void LCD_SetPosition ( cX )
    This subroutine works specifically for 4-bit Port A.
    Value received cX will place cursor at a particular line and offset.
                   16-char display   20-char display
    Line 1 is hex:     00 - 0F           00 - 13
    Line 2 is hex:     40 - 4F           40 - 53
    Line 3 is hex:     10 - 1F           14 - 27
    Line 4 is hex:     50 - 5F           54 - 67
    DATA = swap ( cX ) | 0x08;
    PULSE_EN;
    DATA = swap ( cX );
    PULSE_EN;
void LCD_PutChar ( cX )
    /* this subroutine works specifically for 4-bit Port A */
    RS = 1;
    DATA = swap ( cX );     /* send high nibble */
    PULSE_EN;
    DATA = swap ( cX );     /* send low nibble */
    PULSE_EN;
    RS = 0;
void LCD_PutCmd ( cX )
    PULSE_EN;
    PULSE_EN;
/* Include this file by inserting the line "#include <jonsinc.h>" at
the beginning of the C source code.  Or, if you prefer, you can embed it's
contents at the end of each of your 12C509H, 16F84H, 16F874.H, etc. files.*/
#case
#ifndef TRUE
#define TRUE 1
#ifndef FALSE
#define FALSE 0
#ifndef YES
#define YES 1
#ifndef NO
#define NO 0
#ifndef HIGH
#define HIGH 1
#ifndef LOW
#define LOW 0
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
#ifndef UP
#define UP 1
#ifndef DOWN
#define DOWN 0
#ifndef UCHAR
#define UCHAR char
#ifndef UINT
#define UINT long
#ifndef BIT
#define BIT short
#ifndef SCHAR
#define SCHAR signed int
#ifndef SINT
#define SINT signed long
#ifndef FLOAT
#define FLOAT float
so...
hadeelqasaimeh
PostPosted: Sun Dec 17, 2006 7:09 am     Reply with quote
i face the same proplem.
http://www.ccsinfo.com/forum/viewtopic.php?t=27544
when add a lcd library ,,give me errors.
thanx
PostPosted: Sun Dec 17, 2006 7:40 am     Reply with quote
What is the error message you get?
Which compiler version are you using?
Don't put this line here, have it in the same file where the #fuses line is. Now you are runing the risk of declaring the clock speed twice with unknown results.
hadeelqasaimeh
PostPosted: Mon Dec 18, 2006 10:01 am     Reply with quote
it give this message
undefined identifier PS2KEY_BUF_SIZE
my compiler is 3.249
hadeelqasaimeh
PostPosted: Thu Dec 21, 2006 1:22 am     Reply with quote
helllllooo!!!
nobody can help?
PostPosted: Thu Dec 21, 2006 1:37 am     Reply with quote
it give this message,
Notice that in your code, you have this statement:
#case
Notice that in John Leung's code, he spells that constant name
two different ways. He doesn't use the #case statement in his
code, so he doesn't get an error.
PS2Key_BUF_SIZE
PS2KEY_BUF_SIZE
