I/O pin management
xav27
I/O pin management
PostPosted: Fri Apr 09, 2004 2:58 am     Reply with quote
I'm trying to use unused pin of my PIC to do 8 bit DATA bus I/O.
for example, if I have RA0,RA1,RA4,RB2,RB5,RB7,RC0,RC5 pin unused, how can I outpout/inpout a byte using this pin ?
0) is it possible ?
1) how to do correct pin affectation (something like a struct ????)
2) how to correctly set TRIS registers for read and write operation
Hope I'm clear enought ?!
Thanks in advance
Xavier
Haplo
PostPosted: Fri Apr 09, 2004 3:43 am     Reply with quote
Of course it is possible. The best way to do it would be using structs. Look at the LCD.C file in the \drivers directory for more details.
Userrr
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Haplo answered me
PostPosted: Fri Oct 15, 2004 1:31 pm     Reply with quote
answered me:
this LCD.c struct
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
But how with 2 ports
CAN I Do something as it
struct port_new {
int1 PORTB.0;
int1 PORTB.1;
int1 PORTA.5;
int1 PORTA.6;
int1 PORTB.3;
int1 PORTB.5;
int1 PORTA.1;
int1 PORTA.0;
} ports;
how I must do it
PostPosted: Fri Oct 15, 2004 1:35 pm     Reply with quote
What you want is Mark's method. He posted it in the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=20182
Userrr
Thanks PCM Programmer
PostPosted: Fri Oct 15, 2004 3:05 pm     Reply with quote
Userrr
But
PostPosted: Fri Oct 15, 2004 3:21 pm     Reply with quote
But here I can't get this:
PORTNEW=0xFF - function
and that is mean that as example
PORTA=0x0F and PORTB=0x0F
PORTNEW { RA0,RA1,RA2,RA3,RB0,RB1,RB2,RB3}
PCM programmer please answ. me
PostPosted: Fri Oct 15, 2004 5:30 pm     Reply with quote
There are many ways to do it. It's a question of which way
is the most efficient. It's also a question of how much time
do you (or I) want to spend on it. Here is one way:
#include <16F877.H>
#use delay(clock = 4000000)
// We want to be able to write a byte value to the following spare pins.
// RA0,RA1,RA4,RB2,RB5,RB7,RC0,RC5
// Define the bit addresses of the spare pins.
// The addresses shown below are for the 16F877.
#bit RA0 = 5.0
#bit RA1 = 5.1
#bit RA4 = 5.4
#bit RB2 = 6.2
#bit RB5 = 6.5
#bit RB7 = 6.7
#bit RC0 = 7.0
#bit RC5 = 7.5
// The following macro defines the "set_spare_bits()" function.
// This will be implemented by the compiler as eight sequential
// BSF or BCF instructions.
#define set_spare_bits(x)  \
RA0 = x & 1;         \
RA1 = (x >> 1) & 1;  \
RA4 = (x >> 2) & 1;  \
RB2 = (x >> 3) & 1;  \
RB5 = (x >> 4) & 1;  \
RB7 = (x >> 5) & 1;  \
RC0 = (x >> 6) & 1;  \
RC5 = (x >> 7) & 1
// The TRIS must be set for the spare pins before the function is
//  called.   The spare pins must be set as outputs.
set_tris_a(0b11101100);
set_tris_b(0b01011011);
set_tris_c(0b11011110);
set_spare_bits(0x55);
The program above compiles to the following code:
0000                00309 ..... set_tris_a(0b11101100);
0014 30EC       00310 MOVLW  EC
0015 1683       00311 BSF    03.5
0016 0085       00312 MOVWF  05
0000                00313 ..... set_tris_b(0b01011011);
0017 305B       00314 MOVLW  5B
0018 0086       00315 MOVWF  06
0000                00316 ..... set_tris_c(0b11011110);
0012 30FF       00317 MOVLW  FF
0013 00A1       00318 MOVWF  21
0019 30DE       00319 MOVLW  DE
001A 0087       00320 MOVWF  07
001B 1283       00321 BCF    03.5
001C 00A1       00322 MOVWF  21
0000                00323 .....
0000                00324 ..... set_spare_bits(0x55);
001D 1405       00325 BSF    05.0
001E 1085       00326 BCF    05.1
001F 1605       00327 BSF    05.4
0020 1106       00328 BCF    06.2
0021 1686       00329 BSF    06.5
0022 1386       00330 BCF    06.7
0023 1407       00331 BSF    07.0
0024 1287       00332 BCF    07.5
Edited to fix the mistake in the last line of the set_spare_bits()
macro, as noted in the post below.
Edited to put code in a Code Block.
Last edited by PCM programmer on Thu Apr 07, 2011 10:03 am; edited 3 times in total
aaaaamartin
PostPosted: Thu Dec 14, 2006 1:43 pm     Reply with quote
what if I need input and output ?
Regards Martin
PostPosted: Thu Dec 14, 2006 5:00 pm     Reply with quote
The demo program below shows how to read eight spare bits and pack
them into a byte variable.
You don't need to set the TRIS if you're running the compiler in Standard
i/o mode. The compiler will handle it, since I'm using CCS i/o functions
in the macro. ("Standard i/o" mode is the default mode of the compiler).
#include <16F877.H>
// This macro reads the value of the following
// pins and packs the result into a single byte.
#define read_spare_bits(x) \
x = 0; \
if(input(PIN_A0)) bit_set(x, 0); \
if(input(PIN_A1)) bit_set(x, 1); \
if(input(PIN_A4)) bit_set(x, 2); \
if(input(PIN_B2)) bit_set(x, 3); \
if(input(PIN_B5)) bit_set(x, 4); \
if(input(PIN_B7)) bit_set(x, 5); \
if(input(PIN_C0)) bit_set(x, 6); \
if(input(PIN_C5)) bit_set(x, 7);
int8 result;
   // Read the value of the spare bits and put
   // it into the 'result' variable.
   read_spare_bits(result);
   printf("Result = %X \n\r", result);
PostPosted: Mon Jan 08, 2007 5:21 am     Reply with quote
I've just tried implementing the above macro set_spare_bits() and instead of turning on a static image on the 7-seg it cycles through the segments, one at a time, starting with one segment and then two, three, four, etc.
PostPosted: Mon Jan 08, 2007 11:17 am     Reply with quote
Read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18183&highlight=leds+read+modify+write
Questions:
1. What PIC are you using ?
2. Can you post a list of the Port pins that you're using ?
