Unwanted Automated ASM code
joshkeys
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Dec 14, 2006 12:48 pm     Reply with quote
Hello all,
I have been using ASM code throughout my programs to get certain aspects of my code more efficient. The problem I am running into is that when i compile, the compiler inserts unecessary ASM lines that I dont want, such as is shown below.
.................... BSF    0x05.2
0076:  BCF    03.5
0077:  BSF    05.2
The problem here is that I do not want it to set the bank to bank 0 because I have already done this a few lines before and the status register is still set to bank 0. But yet it sets it for me, and also at the end of a while statement, it goes ahead and sets teh status register to bank 0 again. I am really desperate for CPU cycles here and would like to save as many as possbile. so how can i stop it from doing this. Thanks
Josh[/code]
drh
PostPosted: Thu Dec 14, 2006 1:42 pm     Reply with quote
Are you using #asm...#endasm directives?
If so, using #asm ASIS will stop the compiler
from setting the banks.
David
joshkeys
PostPosted: Thu Dec 14, 2006 1:48 pm     Reply with quote
yes, I use #asm and #endasm. It still decides to add a line when it feels like to make sure the proper bank has been set.
Josh
PostPosted: Thu Dec 14, 2006 2:57 pm     Reply with quote
I tested the ASIS directive with PCM vs. 3.249 and I found that it is
effective in preventing the compiler from putting in bank switching code.
Here is the result with ASIS. There's no bank select code:
.................... #asm    ASIS
.................... MOVF EECON1,W
000C:  MOVF   0C,W
.................... MOVF EEDATA,W
000D:  MOVF   0C,W
.................... MOVF TXSTA,W
000E:  MOVF   18,W
.................... MOVF RCREG,W
000F:  MOVF   1A,W
.................... #endasm
With ASIS commented out, the compiler puts in bank select code:
.................... #asm //   ASIS
000C:  BSF    03.6
000D:  MOVF   0C,W
000E:  BCF    03.5
000F:  MOVF   0C,W
0010:  BSF    03.5
0011:  BCF    03.6
0012:  MOVF   18,W
0013:  BCF    03.5
0014:  MOVF   1A,W
Here's the test program:
#include <16F877.H>
#byte RCREG  = 0x1A
#byte TXSTA  = 0x98
#byte EEDATA = 0x10C
#byte EECON1 = 0x18C
#asm //   ASIS
MOVF EECON1,W
MOVF EEDATA,W
MOVF TXSTA,W
MOVF RCREG,W
#endasm
joshkeys
PostPosted: Thu Dec 14, 2006 4:48 pm     Reply with quote
As usual, thanks PCM Programmer. Worked 100%. Now no more unexpected timing issues! Thanks!
Josh
drh
PostPosted: Fri Dec 15, 2006 9:05 am     Reply with quote
Josh
Did you read all of my reply?
David
joshkeys
Sorry
PostPosted: Fri Dec 15, 2006 2:49 pm     Reply with quote
drh, i apologize, I guess I did not read the whole thing, well i am sure i did, but i guess as soon as i read the #asm and #endasm In my mind I had already formed an answer.. Embarassed .. I apologize, I am not usually so quick to read something, I was in a rush at that time. My bad.. Thanks for the tip Very Happy
Josh
