hatanet
| split a 16-bit structure into 2x 8-bit message bytes |
Posted: Fri Aug 22, 2003 7:28 am |
Hi Guys,
How can I split a 16-bit structure like the one below into 2x 8-bit message bytes, in order to pass the to a procedure as shown.
struct ADDRESS_16B {
int DEPL : 5; // DEPL[4:0]
boolean izero; // unused_discriptor [5]=0
int STRU : 2; // STRU[7:6]
int BUF : 4; // DEPL[11:8]
int discriptor : 4; // discriptor[15:12]=0x00
} ADDR_16B;
void osd_16_send(unsigned char MSB_Message, unsigned char LSB_Message) { }
Dankie!
Hatanet
___________________________
Original Post ID: 144517148 |
Mark
| Re: split a 16-bit structure into 2x 8-bit message bytes |
Posted: Fri Aug 22, 2003 9:21 am |
void osd_16_send(unsigned char *pMessage)
// *pMessage - contains LSB
pMessage++;
// *pMessage - contains MSB
// You can probably do this also
// pMessage[0] - contains LSB
// pMessage[1] - contains MSB
osd_16_send(&ADDR_16B);
:=Hi Guys,
:=How can I split a 16-bit structure like the one below into 2x 8-bit message bytes, in order to pass the to a procedure as shown.
:=struct ADDRESS_16B {
:= int DEPL : 5; // DEPL[4:0]
:= boolean izero; // unused_discriptor [5]=0
:= int STRU : 2; // STRU[7:6]
:= int BUF : 4; // DEPL[11:8]
:= int discriptor : 4; // discriptor[15:12]=0x00
:= } ADDR_16B;
:=void osd_16_send(unsigned char MSB_Message, unsigned char LSB_Message) { }
:=Dankie!
:=Hatanet
Original Post ID: 144517149 |
R.J.Hamlett Guest
Posted: Fri Aug 22, 2003 3:28 pm |
:=Hi Guys,
:= } ADDR_16B;
:=Dankie!
:=Hatanet
There are a lot of methods of doing this, with various degrees of 'elegance'. One method has allready been posted. Another solution, is to simply declare a union, with a two byte array, declared to occupy the same space (generally this results in _very_ compact code, making it my 'favourite' way of doing this type of transfer). Hence something like:
union {
struct ADDRESS_16B ADDR_16B;
int8 b[2];
} STOR;
Then instead of accessing 'ADDR_16B.discriptor', you would access 'STOR.ADDR_B.disriptor', while to access the bytes, you can then access STOR.b[0], and STOR.b[1].
You can allways use 'brute force casting', on the address of a variable, so (for instance), on the original variable (ADDR_16B), you can use:
*((char *)&ADDR_16B)
which should happily give the first byte, while:
*((char *)&ADDR_16B+1)
should give the second. I am (historically) a little careful of using pointer arithmetic, since it was an area the compiler had several problems with in the past. It does seem OK now though.
Original Post ID: 144517159 |
