Newbie - Assigning values to array during runtime
rwskinner
PostPosted: Sun Dec 10, 2006 3:41 pm     Reply with quote
int buffer[8]
Can I assign values at run time like this?
buffer = {1,2,3,4,5,6,7,8};
I do I have to do it long hand
buffer[0] = 1;
buffer[1] = 2;
Sorry, new to C and I know I can set the values during compile time when I declare the var but I didn't know of an easy way during runtime.
PostPosted: Sun Dec 10, 2006 3:59 pm     Reply with quote
buffer[0] = 1;
You could copy a constant array to the RAM buffer with the memcpy()
function. I tested this with PCH vs. 3.249 and it works. Here's the
output of the program shown below:
01 02 03 04 05 06 07 08
#include <18F452.h>
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP
char const data[8] = {1,2,3,4,5,6,7,8};
main(void)
int8 i;
int8 buffer[8];
// Copy the constant array to the RAM array.
memcpy(buffer, data, sizeof(data));
// Display the contents of the RAM array.
for(i = 0; i < sizeof(buffer); i++)
    printf("%X ", buffer[i]);
