gs
Joined: 22 Aug 2005 Posts: 30 Location: Ioannina - Greece
DS1340 RTC driver |
Posted: Sat Dec 09, 2006 7:55 pm |
Has anyone used a DS1340 before? It is an i2c RTC from dallas-maxim.I would be grateful if you share some tested code.
I know it is almost the same as DS1307, and most if the code will be the same. I noted the changes needed on the DS1307 driver on paper. The initializing rutine needs some work.
For now I dont have the real chip availiable yet, so I cant test any code.
greetings from Greece ;) _________________ www.hlektronika.gr |
