otavio_fisica
Problem with DS1621 and PIC16F819 and RS-232 communication. |
Posted: Sat Dec 09, 2006 10:27 am |
Hi, I have built a system to read temperature using the DS1621 and the PIC16F819. This PIC reads the temperature from the DS1621 through I2C and sends the data to the computer through RS-232. I am using the following code for tests (PIN_B1 and PIN_B4 are the ones used for the I2C communication):
I'm using PCM 3.235 version.
#include <16F819.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A4,bits=8,stream=TEMP)
#use i2c(Master,sda=PIN_B1,scl=PIN_B4, force_HW)
while(true)
fprintf(TEMP,"Iniciando medida... \n\r");
output_high(PIN_B1);
output_high(PIN_B4);
i2c_start();
i2c_write(0x90);
i2c_write(0xac);
i2c_write(3);
i2c_stop();
delay_ms(20);
i2c_start();
i2c_write(0x90);
i2c_write(0xee);
i2c_stop();
delay_ms(800);
i2c_start();
i2c_write(0x90);
i2c_write(0xaa);
i2c_start();
i2c_write(0x91);
data1=i2c_read();
data2=i2c_read(0);
i2c_stop();
fprintf(TEMP,"Temperatura: %c - %d\n\r", data1, data2);
This is not the final code. I've built it just to test the communication. I have two problems. The first one is with the RS-232 communication. I use the MAX232N for this purpose. When the PIC is not tied to the VCC, it sends the data to the computer perfectly! (CRAZY...) But when I put the PIC tied to the VCC, then it starts sending parts of what it should send in time intervals that do not correspond to those of the code. Again, when I turn the VCC off (for the PIC) it sends the information perfectly, in the correct time instants. This is one problem... the second one is that it returns (when the PIC is not tied to the VCC) the information: "Temperatura: - -1". That is, data1 does not return any value and data 2 returns "-1". I am going crazy with this. I have already used the same schematic for the RS-232 and I2C communication with other PIC and other slave and it worked fine.
Does someone have any suggestion of what could be happening.
Any information would be of great value. |
Posted: Sun Dec 10, 2006 4:33 pm |
Quote: | When the PIC is not tied to the VCC, it sends the data to the computer
perfectly! But when I put the PIC tied to the VCC, then it starts sending
the information perfectly, in the correct time instants. |
If the PIC runs when the Vdd voltage is removed from it, then it
means the PIC is getting power from an i/o pin (possibly through
a pull-up resistor).
My guess is that you have a problem with your hardware connections.
You may be missing a common ground (Vss) connection between the
chips and the power supply on your board. It will be something like that. |
Sherpa Doug Guest
Posted: Sun Dec 10, 2006 5:05 pm |
When the PIC is NOT connected to VCC measure the voltage on the PIC VCC pin and on all of its I/O pins. One or more of the I/O pins will be higher than the VCC pin by a few tenths of a volt, and that pin(s) is providing power to the PIC. Also double check your grounds. |
otavio_fisica
Posted: Mon Dec 11, 2006 12:02 pm |
I've checked which is the I/O the pic is getting voltage from. It's from the pin used as RX. I tried to change the pins in the pic, but nothing different happened. I have also checked all the ground connections and they are perfect. I still do not know what to do... And about the software? Do you think it will work if this first problem is solved?
Thanks for your help. |
