jab351c
math problem |
Posted: Mon Dec 04, 2006 5:48 pm |
I went through and did these math calculations by hand and got the correct answer. My adc is at approximately 512 at room temperature. I am not sure if I am dealing with negative numbers correctly because my output on the LCD does not match my calculations at all. Any ideas on what may be going wrong?
thanks,
Jeff
Code: | #include <math.h>
float W0,W1,W2,W3,W4,W5,VB,RT,TC,TF;
W0=0.001116401465500;
W1=0.000237982973213;
W2=-0.000000372283234;
W3=0.000000099063233;
gettmp: set_adc_channel(3); //(ADC Channel Input-3)
W4=read_adc(); //Sample ADC Input Voltage
VB=W4*(5/1023);
RT=VB/((5-VB)/10100);
W5=(LOG(RT));
TC=(1/(W0+(W1*(LOG(RT)))+(W2*W5*W5)+(W3*W5*W5*W5)))-273.15;
TF=(TC*1.8)+32;
lcd_putc(0x0c); //Clear the LCD
lcd_gotoxy(1,1); //Set the Cursor to Position-1 of Line-1
printf(lcd_putc,"Degrees C=%lf",TC); //Send, Degrees C=, to the LCD in Long Integer Floating Point Form
lcd_gotoxy(1,2); //Set the Cursor to Position-1 of Line-2
printf(lcd_putc,"Degrees F=%lf",TF); //Send, Degrees F=, to the LCD in Long Integer Floating Point Form
delay_ms(2000); //Pause or Delay for 2 seconds
goto gettmp; |
Posted: Mon Dec 04, 2006 6:07 pm |
Quote: | printf(lcd_putc,"Degrees F=%lf",TF); |
The floating point format specifier ("%f") doesn't need or accept
an "l" (lower case L) modifier.
Download the CCS manual.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look at the printf() function parameters on page 196 in the Acrobat
reader. It shows which ones can accept an "L" modifer.
There are other errors.
When you set or change the A/D channel, you need to put a delay
after it. This is in the data sheet. Add the line shown in bold below:
Quote: |
set_adc_channel(3);
delay_us(20);
The compiler doesn't know that you want to do floating point math
unless you tell it to do so. For example, in your code below, the
compiler will do integer math on the "5/1023" expression. The compiler
will evaluate that expression as 0. It will then multiply W4 by 0.
You need to tell the compiler that the numeric values are floating point.
Do this by adding a '.0' after each number. Example:
Code: | VB=W4*(5.0/1023.0); |
There are other lines in your program that need to be fixed in the
same way.
Also, we don't normally use "goto" statements in C. Instead, you
should use a while(1) loop. Example:
// Put your loop code in here.
jab351c
Posted: Mon Dec 04, 2006 10:45 pm |
Ok, I took your advice on everything except the goto. I will change it to a while loop eventually probably. I am still not getting the correct output on the LCD. Actually I am getting the exact same output as the last time. My question is if I have other things hooked upto port a(sending in other signals) will this interfere with my adc on pin_A3? I dont think it should if I am only using pin_A3 should it?
thanks,
Jeff
setup_port_a(AN3);
setup_adc(VSS_VDD);
setup_adc(ADC_CLOCK_DIV_4);
setup_adc(ADC_TAD_MUL_12);
set_adc_channel(0);
gettmp: set_adc_channel(3); //Analog Input (ADC Channel Input-3)
delay_us(20);
W4=read_adc();
VB=W4*(5.0/1023.0);
RT=VB/((5-VB)/10100.0);
W5=(LOG(RT));
TF=(TC*1.8)+32.0;
printf(lcd_putc,"Degrees C=%f",TC);
printf(lcd_putc,"Degrees F=%f",TF);
goto gettmp;
Posted: Mon Dec 04, 2006 11:05 pm |
Quote: |
setup_adc(VSS_VDD);
You can't call setup_adc() three times with individual constants.
You will never see this, in any of the CCS example files or in the
sample code posted by the people who answer questions on this forum.
The constants have to be bitwise OR'ed together, as described in
the .H file for your PIC. |
