I am implementing a bootloader that uses serial to receive hex data using the #use rs232 directive and get/put commands.
Does my code use interrupts? Do I have to pay attention to interrupts redirection?
Thanks,
Andre
Posted: Wed Nov 29, 2006 3:02 am
Getc, and putc, do not themselves use interrupts. You are only using interrupts, if you have a #int directive. The question though is what you 'main' code uses, rather than what the bootloader does.
Posted: Wed Nov 29, 2006 3:27 am
You only have to redirect interrupts when:
1) Your bootloader is at the start of memory.
or
2) The bootloader is _not_ at the start of memory and using interrupts.
