Variable Frequency Pulse Needed
Greg_R
PostPosted: Tue Nov 28, 2006 7:01 pm     Reply with quote
PIC18F65J15
50Hz to 1kHz with at least 7 bits
My circuit has a stepper motor controller/driver that requires a pulse for each step. The speed has to be ramped but is otherwise constant for long periods of time. I want to avoid using an interrupt as it will fire every 1 to 20 ms. I'm shooting for a nice deterministic main loop...
The PWM frequency options look to be too coarse and too fast.
I didn't see a way to set the Compare function so that it would both reset the timer and toggle the CCP pin.
Any ideas?
Greg
Greg_R
Additional Details
PostPosted: Tue Nov 28, 2006 7:05 pm     Reply with quote
10Mhz Crystal with 4xPLL
Design is not in layout yet so any pin can be made available.
Greg
SherpaDoug
PostPosted: Tue Nov 28, 2006 9:51 pm     Reply with quote
Try googling "numerically controlled oscillator". I did one on a 20MHz 16C58 PIC that went up to 35kHz.
Greg_R
Just need a pulse without using an interrupt...
PostPosted: Tue Nov 28, 2006 10:06 pm     Reply with quote
SherpaDoug,
Thanks for the suggestion but unless I missed something it doesn't answer the question. I'm simply looking for ways to avoid using an interrupt. Everything else the circuit needs to do will fit into a simple task schedule.
Greg
Greg_R
dsPIC solved the problem
PostPosted: Tue Dec 19, 2006 4:35 pm     Reply with quote
Turns out the compare modules on the dsPIC33s will do exactly what I need. Good thing the system also has one of them...
Greg
