Problem with watchdog on a 18F2520
nilsener
PostPosted: Tue Nov 28, 2006 9:44 am     Reply with quote
My watchdog on a 18F2520 overflows each 2.18 minutes as it is given in the datasheet (section 23.2, page 260) as the max time for the watchdog. Clearly, 2.18 minutes is far to much. How can I adjust the watchdog to shorter times?
I use:
#fuses HS,WDT,PUT,PROTECT,NOMCLR,CPD,BROWNOUT,NOIESO,NOFCMEN,NODEBUG,INTRC_IO,NOLVP
Thanks for any help!
Best Regards
nilsener
davekelly
PostPosted: Tue Nov 28, 2006 9:55 am     Reply with quote
Use the setup_wdt() function.
Refer to the manual for the time constants.
nilsener
PostPosted: Tue Nov 28, 2006 10:08 am     Reply with quote
problem solved. The fuse WDT seems to set the watchdog to max time. I now use the fuse WDT256 to get adequate times.
