Peter-NMB
Joined: 17 Sep 2003 Posts: 11 Location: Glasgow, Scotland
Anyone Used a TMP141 with a PIC (Sensorpath)? |
Posted: Wed Nov 22, 2006 10:58 am |
Has anyone here used the Ti TMP141 Single wire Temperature Sensor before?
If so how did you find using the SensorPath Bus.
http://focus.ti.com/lit/ds/symlink/tmp141.pdf |
Posted: Wed Nov 22, 2006 2:03 pm |
There's not much information available on this bus. Here's one page:
http://www.national.com/nationaledge/jan04/article.html
Down at the bottom, they give a link to a site where supposedly the
specification is available, except it's not there. A web search for the
spec ends up with nothing.
There are no appnotes available on the inventor's website (national.com).
This bus looks to me as if it's an "in house" bus, intended for motherboard
manufacturers. They don't really care about publishing the spec, or
appnotes, or anything. That's my assessment. |
Peter-NMB
Posted: Thu Nov 23, 2006 4:17 am |
Hi PCM Programmer,
I found a similar situation in regard of acquiring information about sensorpath, I had been on the same link as you had suggested and also spent a fair while navigating around the http://www.dmtf.org to find the specification of which I was unable to locate.
I have since tried to contact Ti (who also have no apps notes) and National, hopefully they will get back to me with information. Initial information given from National is that the technology was given/sold to Winbond though.
(I had just thought since these parts are highly noise immune and relatively low cost due to their applications on motherboards that it would be a good part to use in future applications).
Any info that I acquire I will post, so that anyone interested in Sensorpath can have a wee look. I'll keep searching
Thanks for looking into it though  |
SET
Posted: Thu Nov 23, 2006 11:41 am |
Hi Peter
Also couldn't find anything on dtmf site - but there was timing information on one of the manufacturers sites (cant remember whether it was TI or National) and it does look very similar to 1-wire at the physical level, although it also has a protocol above that.
I had the same thought too, that these devices might be of use other than on motherboards!
Vic |
adrian
Peter-NMB
Posted: Mon Nov 27, 2006 2:50 am |
Hi Adrian,
I had been around these pages already, except for the National Page about the details of the Winbond/ National transfer.
the most interesting page that was listed was the
http://lists.lm-sensors.org/pipermail/lm-sensors/2004-August/008631.html
When I found this one however, It gave a lot of links.
I was unable to get the PDF on the link that looked the most interesting when I followed the thread, as the page no longer seems to exist.
http://www.national.com/an/AN/AN-1316.pdf
Thanks Adrian, for looking though. Have you used sensorpath before? |
adrian
Posted: Tue Nov 28, 2006 2:25 am |
Peter-NMB wrote: | Thanks Adrian, for looking though. Have you used sensorpath before? |
No just trying to help out an ex colleague |
Posted: Tue Nov 28, 2006 1:13 pm |
That appnote is about the National PC8374L Super I/O chip.
National has sold that product line to Winbond. It looks like
someone has gone through the appnotes and pulled anything
that applies to the Super I/O product line. Winbond has not
(so far) re-posted the appnote on their webpage. That's why
you can't find it. |
