PIC18F4520 bootloader question
iw2nzm
PostPosted: Sun Nov 26, 2006 11:41 am     Reply with quote
I'm new to bootloaders. I have a PIC18F4520 with a 10Mhz oscillator.
I need to update firmware via RS232. I would like to send an 'upgrade' command and then reset the micro with reset_cpu() function.
After the reset the bootloader should wait for a while and if the host send a start command begin the update.
I modified the bootloader example in this way:
#elif defined(__PCH__)
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#define _bootloader
#include <bootloader.h>
#include <loader.c>
#if defined(__PCM__)
 #org LOADER_END+1,LOADER_END+10
 #org LOADER_END+2,LOADER_END+30
void application(void) {
  while(TRUE);
#if defined(__PCH__)
#org 0x40,0x7F
#else
#org 0x20,0x3F
   long timeout;
   timeout=0;
   while(!kbhit() && (++timeout < (100000)))
      delay_us(10);
   if(kbhit())
      load_program();
      application();
#ORG default
#int_global
void isr(void) {
   jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
I get this error:
error - 71: out of ROM, a segment or the program is too large. Main.
I guess it is due the change I made: the new code size is greater than the example. However, I don't know how fix it. Is there a problem with an #ORG directive?
Could anyone help me, please?
Than you
Marco / iw2nzm
PostPosted: Sun Nov 26, 2006 12:56 pm     Reply with quote
That's not the full error message. I put your program into MPLAB
and compiled it with PCH vs. 3.249. I got this:
Error 71 "C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.c"
Line 74(0,1): Out of ROM, A segment or the program is too large
main Seg 00040-0007E, 0040 left, need 0046
The last line is a major clue. You have this line in your code:
#org 0x40,0x7F
What should be done to that line of code to increase the segment size ?
Get the current CCS manual:
http://www.ccsinfo.com/downloads.php
Look in the section on #org. How are the two numbers in the #org
statement used ? Which one should you change ?
iw2nzm
PostPosted: Sun Nov 26, 2006 3:23 pm     Reply with quote
#org 0x40,0x7F
[...] How are the two numbers in the #org
Well, I guess I should change the first parameter. I replaced it with a smaller one and now it works. I'm trying to download new firmware now.
Thank you
Marco / iw2nzm
Vamsi
Sameproblem
PostPosted: Wed Nov 14, 2007 2:34 pm     Reply with quote
Hi guys,
i still have the same problem. Though i change 0x40 to a lower value i still get the same error.
Can anyone help me in this ? Actually i am using PIC18F4520.h and not 18F452
Thank you,
Vamsi
PostPosted: Wed Nov 14, 2007 3:54 pm     Reply with quote
Vamsi, please stick to your original thread.
Posting in an old thread from someone with similar but slightly different problems is confusing and will not get you the correct answers.
