compatibility problem?
koko
PostPosted: Fri Nov 24, 2006 6:42 am     Reply with quote
i have two ccs compillers, v3.124 and v3.249. the problem is: my code compils fine with old version, but not with the new one. the same code, with no changes! target device is 16f877a. can somebody help me?
PostPosted: Fri Nov 24, 2006 6:55 am     Reply with quote
Realistically, archive the old compiler with the source, and use this....
The 'answer' gets complex, and will depend on how your code is written. There are some 'little' changes, which have caused this type of behaviour. The way that bit fields are handled can affect some complex logic tests. The improved optimisation, can cause problems, in particular if you are mixing assembler with your C. Try running with the optimisation turned down. There have been some slight 'tweaks' to some of the library routines (make sure that your code is pulling the libraries that correspond to the latter compiler, when trying to compile with this).
koko
PostPosted: Fri Nov 24, 2006 8:15 am     Reply with quote
thanks, Ttelmah.
i made some changes in my code, but there is new problem, even more strange. the code now compils with both compilers, but work only if it was compiled with old version! Shocked Shocked
PostPosted: Fri Nov 24, 2006 10:58 am     Reply with quote
Read my post near the end of this thread. You may have the same
problem. It's caused by changing the compiler version, but keeping
a local copy of the .H file from the older compiler in your project directory:
http://www.ccsinfo.com/forum/viewtopic.php?t=18783&highlight=constants
