ICD 2 + MPLAB and CCS plugin
Mauricio Lopes
PostPosted: Tue Nov 21, 2006 6:06 am     Reply with quote
Hello All,
I need some help. I tried to compile a program with LCD driver(LCD.C) in MPLAB using the CCS Plugin, but it shows many error messages about the LCD driver. I think that isnt LCD driver cause its compile normally in the CCS 3.249, but it not works in MPLAB7.40.
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Arquivos de programas\PICC\Ccsc.exe" "EX_LED.C" +FM +DF +LN +T -A +M -Z +ICD +Y=9 +EA
*** Error 12 "C:\ARQUIV~1\PICC\drivers\LCD.C" Line 100(7,15): Undefined identifier  -- delay_us
*** Error 12 "C:\ARQUIV~1\PICC\drivers\LCD.C" Line 112(7,15): Undefined identifier  -- delay_us
*** Error 12 "C:\ARQUIV~1\PICC\drivers\LCD.C" Line 137(5,13): Undefined identifier  -- delay_ms
*** Error 12 "C:\ARQUIV~1\PICC\drivers\LCD.C" Line 140(8,16): Undefined identifier  -- delay_ms
*** Error 12 "C:\ARQUIV~1\PICC\drivers\LCD.C" Line 162(20,28): Undefined identifier  -- delay_ms
      5 Errors,  0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Tue Nov 21 09:54:59 2006
Thanks a Lot.
Mauricio Lopes
Fabri
PostPosted: Tue Nov 21, 2006 11:17 am     Reply with quote
I use MPLAB 7,40 , ICD 2 and CCS Compiler 3,249 without problem.
Post the program.
Regards,
PostPosted: Tue Nov 21, 2006 11:30 am     Reply with quote
These error messages show that the delay_us() and delay_us()
statements in LCD.c can't find the CCS delay library. This can
happen if you put the #include statement for LCD.c in the wrong
location. It must be placed below the #use delay() statement.
You should put it in the location shown in bold below:
#include <16F877.h>
#include <lcd.c>
Mauricio Lopes
PostPosted: Tue Nov 21, 2006 12:28 pm     Reply with quote
As said as done!!!!
The problem was solved... As said by PCM Programmer, the #include line was in the wrong place...
One more time, thanks a lot....
Mauricio Lopes.
