PWM problem.
guest216
PWM problem.
PostPosted: Fri Nov 17, 2006 11:03 am     Reply with quote
Hi All!
I'm using the PIC18F44J10 and it's ECCP for a motor driver.
I need to use the other PWM channel (CCP2) for other part of the board
but, I just can't 'get' it to work, the pin direction is good and the compiler
show no errors.
Any ideas?
PostPosted: Fri Nov 17, 2006 5:55 pm     Reply with quote
Post a very short test program, in which you setup both CCP1 and CCP2
for PWM. Also post your compiler version.
