JohnLook Guest
Problem with USB |
Posted: Thu Nov 16, 2006 4:23 pm |
Hi, I'm having a problem when I connect the board with PIC18F4550 on USB port. I would like to know why when I connect the cable there isn't no power and windows shows a message of error indicating that the device wasn't recognized. |
TARUN GUPTA
first time i have written code for USB |
Posted: Tue Nov 21, 2006 12:15 am |
hi, i have written time code for USB in 16c745(OTP) using example from ccs c compiler , but i m not 100% sure it works, and i have programmer which burn code in this 16c745/765 family chip. I cant programme the 18f4550 due to probem of programmer....so help me ,how i can write code in ccs c compiler  _________________ hi.....
i wud join this for getting knowledge and for discusssion |
TARUN GUPTA
Posted: Tue Nov 21, 2006 12:17 am |
hi, i have written time code for USB in 16c745(OTP) using example from ccs c compiler , but i m not 100% sure it works, and i have programmer which burn code in this 16c745/765 family chip. I cant programme the 18f4550 due to probem of programmer....so help me ,how i can write code in ccs c compiler Code: |
this programm for testing ...just switch i connected to microcontroller abd transmitting particular data through usb to computer.......
#define USB_PIC16C745 1 //set to 1 to use a PIC16c765 USB Peripheral
//set to 0 to use a National USBN960x peripheral
#include <16C745.h>
#device *=16
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=24000000)
#DEFINE LED_4 PIN_B1 //SENSOR STATUS
#define SENSOR PIN_B2 // IR SENSOR...
#DEFINE LED_3 PIN_B3 // led connected on pin b3 for initial status & button2
#DEFINE LED_2 PIN_B4 // led connected on pin b4 for initial status & button1
#DEFINE LED_1 PIN_B5 // led connected on pin b5
#DEFINE BUTTON1 PIN_B6 // switch connected to pin a4
#DEFINE BUTTON2 PIN_B7 // switch connected to pin a5
#byte port_b=6
//Tells the CCS PIC USB firmware to include HID handling code.
#DEFINE USB_HID_DEVICE TRUE
//Set this to FALSE if you only want to test enumeration. Some USB test programs,
//such as USBCHECK, crash if you are trying to test enumeration and the device
//starts sending data once configured.
#DEFINE USB_RUN_WHEN_CONFIGURED TRUE
//the following defines needed for the CCS USB PIC driver to enable the TX endpoint 1
#define USB_EP1_TX_ENABLE 1 //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE 2 //if you change this, be sure to change the hid descriptor
//the following defines needed for the CCS USB PIC driver to enable the RX endpoint 1
#define USB_EP1_RX_ENABLE 1 //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_RX_SIZE 2 //if you change this, be sure to change the hid descriptor
#if USB_PIC16C745
#include <pic_usb.h> //Microchip PIC16C765 hardware layer for usb.c
#else
#include <usbn960x.c> //National 960x hardware layer for usb.c
#endif
#include <usb.c> //handles usb setup tokens and get descriptor reports
//////////////////////////// MAIN PROGRAM //////////////////////////////////////
void main() {
int8 out_data[USB_EP1_TX_SIZE];
int8 in_data[USB_EP1_RX_SIZE];
int8 out1;
output_b(0xff);
set_tris_b(0x23);
#ifdef __PCH__
printf("\r\n\r\nPCH: v");
printf(__PCH__);
#else
printf("\r\n\r\nPCM: v");
printf(__PCM__);
#endif
// setup_adc(ADC_CLOCK_INTERNAL);
// setup_adc_ports(RA0_RA1_RA3_ANALOG);
// set_adc_channel(1);
usb_init(); // usb initialise function
#if !(USB_PIC16C745)
printf("\r\nUSBN: 0x%X\r\n", usbn_get_version());
bit_clear(port_b, LED_1);
bit_clear(port_b, LED_2);
bit_clear(port_b, LED_3);
bit_set(port_b, LED_1);
bit_set(port_b, LED_2);
#else
printf("\r\n");
#ENDIF
printf("\r\n\r\nWaiting for enumeration...");
while (TRUE) {
usb_wait_for_enumeration();
printf("\r\n\r\n***Enumerated***\r\n");
while(usb_enumerated()) {
#IF USB_RUN_WHEN_CONFIGURED
if (usb_kbhit(1)) {
usb_gets(1, in_data, USB_EP1_RX_SIZE);
printf("\r\n--> Received 2 bytes: 0x%X 0x%X",in_data[0],in_data[1]);
if (in_data[0]) {bit_clear(port_b, LED_1);} else {bit_set(port_b, LED_1);}
if (in_data[1]) {bit_clear(port_b, LED_2);} else {bit_set(port_b, LED_2);}
if (PIN_B2==1){
out1 = 1 ;
bit_set(port_b, LED_4);
delay_ms(5);
out1 = 0 ;
bit_clear(port_b, LED_4);
delay_ms(5);
out_data[0] = out1;
if (BUTTON1==0 && BUTTON2==0)
out_data[1]=2;
delay_ms(5);
if (BUTTON1==0 && BUTTON2==1)
out_data[1]=3;
bit_set(port_b, LED_3);
delay_ms(5);
if (BUTTON1==1 && BUTTON2==0)
out_data[1]=4;
delay_ms(5);
if (BUTTON1==1 && BUTTON2==1)
out_data[1]=5;
delay_ms(5);
if (usb_put_packet(1, out_data, USB_EP1_TX_SIZE, TOGGLE)) {
printf("\r\n<-- Sending 2 bytes: 0x%X 0x%X", out_data[0], out_data[1]);
#ENDIF
printf("\r\n\r\nDevice Un-configured.r\n");
Posted: Tue Nov 21, 2006 12:57 am |
The statements above are incorrect and will not generate any code.
Change them to this:
output_low(LED_1);
output_low(LED_2);
output_low(LED_3);
output_high(LED_1);
output_high(LED_2); |
There are at least 10 more lines in your program that are similar,
and they should be fixed in the same way.
Quote: | if (BUTTON1==0 && BUTTON2==0) |
The statement above is incorrect. Change it to this:
Code: | if (input(BUTTON1)==0 && input(BUTTON2)==0) |
There are many similar lines in your program. They must all be
fixed in the same way. |
