kbhit() does not work ;-(
Kofi
PostPosted: Thu Nov 16, 2006 4:30 am     Reply with quote
I use this code to get chars from uart buffer but the if condition is always true and cIn gets the value <0>.
It is only a test... but why is cIn not 'E' when there is no char in the input buffer ?
#INT_RDA
void RDA_isr(void)
   if(kbhit())
      cIn=getchar();
      cIn = 'E';
please hlp...
Kofi
Kofi
PostPosted: Thu Nov 16, 2006 4:48 am     Reply with quote
I have forgotten to say...
I am usung hardware uart on a PIC16F876A
#fuses NOWDT,HS, NOPUT, NOPROTECT, DEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=19200,parity=N,xmit=TX_PIN,rcv=RX_PIN,bits=8)
PostPosted: Thu Nov 16, 2006 7:09 am     Reply with quote
Because INT_RDA, _will only be called_, when there _is_ a character waiting. That is the whole 'point' of the interrupt. The same code, sitting in your 'main', will work fine, since it is then being called all the time as youloop/wait etc..
'kbhit', does nothing inside the interrupt handler.
Kofi
PostPosted: Thu Nov 16, 2006 8:59 am     Reply with quote
the problem was that everytime i sent data there was an edge on the RX pin i solved it with a 10K resistor to VCC.
dbotkin
PostPosted: Thu Nov 16, 2006 9:14 am     Reply with quote
... but, if I read the ASM correctly, will always return true. Kbhit() just tests for RCIF, which should still be set when you enter INT_RDA.
PostPosted: Thu Nov 16, 2006 10:39 am     Reply with quote
Exactly.
