Derek Guest
16-bits multiplication/adition problem? |
Posted: Mon Jan 13, 2003 2:07 pm |
I have a quick question in regards to multiplication. I don't seem to be able to multiply/add anything greater than 8bits.
I have the PCH compiler version 3.086 for a PIC16F877.
Here's the code.
int16 temp_window;
temp_window = 1*256;
printf( "\%4x", temp_window ); //displays 0000
temp_window = temp_window + 0xbc;
printf( "\%4x", temp_window ); //displays 00bc
or
printf( "\%4x", temp_window ); //displays 0078
how come the 16 bit variable is truncating???
please help...
___________________________
Original Post ID: 10659 |
Re: 16-bits multiplication/adition problem? |
Posted: Mon Jan 13, 2003 2:16 pm |
:=I have a quick question in regards to multiplication. I don't seem to be able to multiply/add anything greater than 8bits.
:=I have the PCH compiler version 3.086 for a PIC16F877.
You mean the PCM compiler.
:=temp_window = 1*256;
:=printf( "\%4x", temp_window );
In CCS, you have to use "lx" for a 16-bit or 32-bit number.
Original Post ID: 10660 |
Derek Guest
Posted: Mon Jan 13, 2003 3:24 pm |
okay, I tried another test.
int16 temp_window;
temp_window = 0x1234;
printf("\%4x", temp_window);
the result that is printed out is 0034
Why's that??? Please help
:=Here's the code.
:=int16 temp_window;
:=printf( "\%4x", temp_window ); //displays 0000
:=temp_window = temp_window + 0xbc;
:=printf( "\%4x", temp_window ); //displays 00bc
:=or
:=printf( "\%4x", temp_window ); //displays 0078
:=how come the 16 bit variable is truncating???
:=please help...
Original Post ID: 10663 |
Dave Yeatman Guest
Posted: Mon Jan 13, 2003 3:34 pm |
As PCM said "\%4x" is for 8 bit. Try \%4lx".... You are truncating to the two least significant hex digits and adding two leading zeros since you specify four decimal places.... This is not ANSI standard C.
:=okay, I tried another test.
:=temp_window = 0x1234;
:=printf("\%4x", temp_window);
:=the result that is printed out is 0034
:=Why's that??? Please help
:=:=I have a quick question in regards to multiplication. I don't seem to be able to multiply/add anything greater than 8bits.
:=:=I have the PCH compiler version 3.086 for a PIC16F877.
:=:=Here's the code.
:=:=int16 temp_window;
:=:=temp_window = 1*256;
:=:=printf( "\%4x", temp_window ); //displays 0000
:=:=temp_window = temp_window + 0xbc;
:=:=printf( "\%4x", temp_window ); //displays 00bc
:=:=or
:=:=printf( "\%4x", temp_window ); //displays 0078
:=:=how come the 16 bit variable is truncating???
:=:=please help...
Original Post ID: 10664 |
Derek Guest
Posted: Mon Jan 13, 2003 3:52 pm |
Yes, I mean PCM. I though the L portion of \%Lx is the length I would like to specify; as in the example.
\%4X 0012 00FE
:=You mean the PCM compiler.
:=In CCS, you have to use "lx" for a 16-bit or 32-bit number.
Original Post ID: 10665 |
Derek Guest
Posted: Mon Jan 13, 2003 3:57 pm |
Oh, I got it to work. Thanks guys. All this time, I thought it was some sort of type casting problem and it drove me nuts.
Derek
:=As PCM said "\%4x" is for 8 bit. Try \%4lx".... You are truncating to the two least significant hex digits and adding two leading zeros since you specify four decimal places.... This is not ANSI standard C.
:=:=okay, I tried another test.
:=:=temp_window = 0x1234;
:=:=printf("\%4x", temp_window);
:=:=the result that is printed out is 0034
:=:=Why's that??? Please help
:=:=:=I have a quick question in regards to multiplication. I don't seem to be able to multiply/add anything greater than 8bits.
:=:=:=I have the PCH compiler version 3.086 for a PIC16F877.
:=:=:=Here's the code.
:=:=:=int16 temp_window;
:=:=:=temp_window = 1*256;
:=:=:=printf( "\%4x", temp_window ); //displays 0000
:=:=:=temp_window = temp_window + 0xbc;
:=:=:=printf( "\%4x", temp_window ); //displays 00bc
:=:=:=or
:=:=:=printf( "\%4x", temp_window ); //displays 0078
:=:=:=how come the 16 bit variable is truncating???
:=:=:=please help...
Original Post ID: 10666 |
