Write_program_eeprom not working the way it did back in compiler 149 for the PIC1687X chips.
Some change back in compiler 151 has changed the way write_program_eeprom works?
Is it required to do an erase_program_eeprom first now?
Thank you all in advance.
___________________________
Original Post ID: 144516942
Cinko Guest
Re: Write_program_eeprom / erase_program_eeprom
Posted: Wed Aug 13, 2003 12:51 pm
:=Write_program_eeprom not working the way it did back in compiler 149 for the PIC1687X chips.
:=Some change back in compiler 151 has changed the way write_program_eeprom works?
:=Is it required to do an erase_program_eeprom first now?
:=Thank you all in advance.
Please let me know if you are using low or high voltage prog.
Original Post ID: 144516944
Thomas Hauff Guest
Posted: Wed Aug 13, 2003 12:57 pm
:=:=Write_program_eeprom not working the way it did back in compiler 149 for the PIC1687X chips.
:=:=Some change back in compiler 151 has changed the way write_program_eeprom works?
:=:=Is it required to do an erase_program_eeprom first now?
:=:=Thank you all in advance.
:=Please let me know if you are using low or high voltage prog.
This is for a bootloader that i'm working.
The fuse for low voltage programing is set to NOLVP so low voltage programing is off.
Original Post ID: 144516945
