Pic18F2420 Brownout voltage fuses
SET
PostPosted: Tue Nov 14, 2006 12:31 pm     Reply with quote
Hello
I'm trying to set the brownout threshold voltage to 2v, using #fuse BORV20 (this is in PIC18F2420.H) - however compiler says 'Unknown keyword in #FUSES "BORV20" '.
Compiler is V3.214
Anyone else seen this?
PostPosted: Tue Nov 14, 2006 2:22 pm     Reply with quote
I don't have that version of PCH, so I can't check it.
If you have PCWH, it's possible that you can use the Device Editor to
fix the problem. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?p=47147
SET
PostPosted: Wed Nov 15, 2006 12:38 pm     Reply with quote
Thanks PCM,
I also have V3.239, and with this one it worked fine!
This is ok, we are modifying the code in any case so can move to the newer version.
