xvi.lajos
Debugger problem |
Posted: Tue Aug 12, 2003 9:13 am |
I have a serious problem with the PCW debugger.
I seems to worked with 16f876 fine but no I want to use with 16f818.
It's very strange, because it can only runs.
It seems to work fine till I start it to run, it shows the correct value of the RAM and Peripherials in the window, but when I stop it it show everithing to zero in the RAM , EEPROM and the preripherials too.
It hangs up when I try step or step over.
In that situation I can't stop it with the stop button only the reset.
ICD is ICD-S 2.2 firmware 1.07 and PCW3.155
Do you have any thoughts?
Thanks George
___________________________
Original Post ID: 144516925 |
xvi.lajos
Re: Debugger problem |
Posted: Wed Aug 13, 2003 12:08 am |
Thank you for the answer,
It's very interesting because that PCW debugger works fine with 16f876 and doesn' work with 16f818, 819,
I went back and I tryed with PCW 3.136 and the problem is same.
Is it a buggy version too?
George
Original Post ID: 144516937 |
