ch_dupre
| assigning a value to a pointer |
Posted: Tue Nov 07, 2006 11:30 am |
hello forum,
I'm having some trouble with pointers. First I wanted to have a function that return a pointer but the result was weird. I tried different method, but the results are still incorrect.
Here is a sample code
int16 data;
int16* returnPtr(void)
fprintf(COM2, "address of data: %LX\n", &data);
return &data;
void returnPtr2(int16* PTR)
PTR = &data;
fprintf(COM2, "address of PTR: %LX\n", PTR);
int16* ptr;
int16* localPtr;
ptr = returnPtr();
fprintf(COM2, "address of ptr: %LX\n", ptr);
returnPtr2(ptr);
fprintf(COM2, "address of localPtr: %LX\n", localPtr);
localPtr += 0xFF;
localPtr = &data;
Here is the output I get:
address of data: 0605
address of ptr: 0005 <<== I would expect 0605 back
address of PTR: 0005 <<== same thing. I expect 0605 here
address of localPtr: 0005
address of localPtr: 0203 <<==this one makes sense: FF + 5 = 0x203
address of localPtr: 0005 <<== again, I expect 0x0605.
Am I doing something wrong? Or is there a limitation in the compiler.
I've tried using compile V3.249 and V4.013
Thanks,
Christophe |
Posted: Tue Nov 07, 2006 1:52 pm |
The true address for 'data' is 0006. I compiled your program for an
18F452, and then looked at the Symbol Table. It shows that 0006 is the
address.
I think printf is very buggy for displaying the address of a variable.
To fix the problem, I had to cast the '&data' value to an int16, as shown
in bold below. I tested this with PCH vs. 3.249.
| Quote: |
fprintf(COM2, "address of data: %LX\n", (int16)&data);
fprintf(COM2, "address of localPtr: %LX\n", localPtr); |
Then it displays:
| Quote: | address of data: 0006
address of localPtr: 0006 |
I just worked on the last two lines of your program. But it's likely
that you can fix the rest of it in a similar way. |
