Compiler skipping calls to functions??
Neckruin
PostPosted: Mon Nov 06, 2006 6:32 am     Reply with quote
Hi all,
I have found, looking at the .LST file of my project, this strange behaviour:
....................    while(TRUE)
....................       ShowStatus();
0BE8:  BCF    0A.3
0BE9:  GOTO   554
0BEA:  BSF    0A.3
....................       UpdateLamps();
0BEB:  BCF    0A.3
0BEC:  GOTO   6E3
0BED:  BSF    0A.3
....................       TurnOffOut();
0BEE:  BCF    0A.3
0BEF:  GOTO   733
0BF0:  BSF    0A.3
....................       ReadPCF8574();
0BF1:  BCF    0A.3
0BF2:  GOTO   78D
0BF3:  BSF    0A.3
....................       MsgProcess();
0BF4:  BCF    0A.3
0BF5:  GOTO   7B9
0BF6:  BSF    0A.3
....................       ProcCmdBtn(); // <---------- HERE !!!!!!!!!!!!!!!
....................       ErrorHandler();
0C71:  BCF    0A.3
0C72:  GOTO   7CB
0C73:  BSF    0A.3
0C74:  GOTO   3E8
As you can see, the compiler is skipping a function (the one I thought didn't work). Why can this be happening??? Sad
I'm using 3.242 version on a PIC16F877.
Thanks a lot,
Juanma
Neckruin
PostPosted: Tue Nov 07, 2006 3:08 am     Reply with quote
I have noticed the code for that function is quite big and has several calls to subroutines... could this be the reason? Maybe the stack is overflowing and the compiler just avoids the problem by deactivating that function Confused
Any ideas????
PostPosted: Tue Nov 07, 2006 3:17 am     Reply with quote
Read this FAQ topic:
http://www.ccsinfo.com/faq.php?page=lst_out_of_order
Carefully check the .LST file. See if the compiler has stuck the
code for that function somewhere else in the file.
With regard to your stack question, look at the top of the .LST file.
The stack usage is listed there. Post that number, and also post
the percentage usage of RAM and ROM.
Neckruin
PostPosted: Tue Nov 07, 2006 3:23 am     Reply with quote
The requested info:
CCS PCM C Compiler, Version 3.242, 16465               06-nov-06 18:16
               Filename: cod00.lst
               ROM used: 3139 words (40%)
                         Largest free fragment is 2048
               RAM used: 34 (10%) at main() level
                         71 (20%) worst case
               Stack:    7 worst case (6 in main + 1 for interrupts)
PostPosted: Tue Nov 07, 2006 3:27 am     Reply with quote
Do a search of the .LST file for 0BF7. Press Ctrl-F and drop that number
into the Find box and see what it finds. I'll bet that it finds your missing
code.
Neckruin
PostPosted: Tue Nov 07, 2006 3:39 am     Reply with quote
Yes, you are right. If I do a search with the next address just before the call to the function it appears the code for the function.
Does this mean the function is actually executing? In that case the problem must be another one...
PostPosted: Tue Nov 07, 2006 3:45 am     Reply with quote
It should execute, provided that the program isn't hanging somewhere.
Put a printf() statement at the end of each one of those functions,
MsgProcess() and ProcCmdBtn(), and see if it displays the messages.
That should tell you if the program flow is getting to those functions.
Neckruin
PostPosted: Tue Nov 07, 2006 3:54 am     Reply with quote
Ok, thanks a lot PCM. I'll try what you say and I hope to guess what's happening with that function.
THANKS
Very Happy
Neckruin
PostPosted: Tue Nov 07, 2006 5:37 am     Reply with quote
Mmmm, I have found the problem: The Timer 1 interrupt only executes once!!!
I have no idea what can be going on.
Here is my Timer1 ISR code:
#int_TIMER1
void TIMER1_isr() {
   clear_interrupt(INT_TIMER1);
   disable_interrupts(INT_TIMER1);
   ButInputNow = ((PORTA & 0b00100000)>>5) | ((PORTE & 0b00000111)<<1);
   if(ButInputNow != 0x0F && ButInputPrev == 0x0F)
      ButPushedFlag = TRUE;
   ButInputPrev = ButInputNow;
   set_timer1(T125MS);
It is supposed to take place every 25ms as far as the timer is configured as DIV_BY_4 with a 20MHz clock.
Any help or suggestion will be welcome... again Embarassed
Thanks in advance
Juanma
Neckruin
PostPosted: Tue Nov 07, 2006 6:16 am     Reply with quote
Forget about that, I have found the problem:
In the timer0 interrupt, I was seting up the timer 1 instead of the timer 0 by mistake. So, the timer 1 was reset at a higher rate than it overflows...
very stupidly simple...
PostPosted: Tue Nov 07, 2006 8:04 am     Reply with quote
Lots of comments.
You don't need to clear the interrupt in the function. Unless you add the keyword 'noclear' to the definition, the compiler does this for you. Then, don't disable the interrupt in the function. This does nothing, since the hardware of the chip, disables the global interrupts as soon as the interupt handler is called. Now, the logic of your button test function is complex, and potentially may well not do what you expect. In C, operators of the same 'precendence' evaluate in different orders, according to the operator involved. With the rules of precedence applied before this. As written, it ought to probably do what you expect (&& has lower precedence than == or !=), but I'd not want to rely on it. Generally, much better to bracket the sections, to force the evaluation order to be what you expect.
You don't post what you are putting into the value 'T125MS'. As you describe it, should be 34285.
However none of these should stop it working.
The obvious question then becomes, "what happens in the main code, when 'ButPushedFlag' is true"?.
