16F628A - internal oscilator 32 khz or 48 khz??
__JEREK__
PostPosted: Mon Nov 06, 2006 9:51 pm     Reply with quote
Hi guys, I have a question about the "setup_oscillator()" function.
in the datasheet of the PIC 16F628A, pag. 29, say
PCON REGISTER
bit 3 - OSCF: INTOSC oscillator frequency
1 =
4 MHz typical
0 = 37 kHz typical
but in the 16f628a.h of CCS we have:
////////////////////////////////////////////////////////////////// INTERNAL RC
// Constants used in setup_oscillator() are:
#define OSC_48KHZ 0
#define OSC_4MHZ 8
I would like to know what is right, 37 Khz or 48Khz?
how can I configure the internal oscilator to 32 khz?
thank you
PostPosted: Mon Nov 06, 2006 10:19 pm     Reply with quote
Early data sheets specified 37 KHz. Later data sheets changed this
to 48 KHz.
How can I configure the internal oscilator to 32 khz?
With the internal oscillator, your only choices are 48 KHz or 4 MHz.
If you want 32.768 KHz, you can use an external crystal in LP mode.
__JEREK__
PostPosted: Mon Nov 06, 2006 10:41 pm     Reply with quote
PCM programmer, really I had the old datasheet of 16f628.
thank you very much!!
best regards!
