Switch toggle High/Low
Goto page 1, 2  Next
PostPosted: Thu Nov 02, 2006 3:05 pm     Reply with quote
Hi i want to to toggle push button high and low but i can't make it what's wrong with code
while(true){
   static int  mm = 0;
   printf(lcd_putc,"\f Status ");
   switch (input(pin_C0)== mm){
   case 0:
   printf(lcd_putc,"\n Low ");
   case 1:
   printf(lcd_putc,"\n High ");
   mm = 0 ; // reset variable mm
Mark
PostPosted: Thu Nov 02, 2006 3:26 pm     Reply with quote
while(true)
  if (!input(pin_C0))
PostPosted: Thu Nov 02, 2006 3:34 pm     Reply with quote
thanks but i want the status stays for each press like when i press first time the status goes high and stay high when i press another time to go low and stay low like normal switch but in push button
Mark
PostPosted: Thu Nov 02, 2006 4:04 pm     Reply with quote
int state = 0;
while(true)
  while (!input(pin_C0));
  if (state)
    state = 0;
    state = 1;
PostPosted: Thu Nov 02, 2006 4:19 pm     Reply with quote
it dosen't work Rolling Eyes
Mark
PostPosted: Thu Nov 02, 2006 5:10 pm     Reply with quote
post your complete program
PostPosted: Fri Nov 03, 2006 7:36 am     Reply with quote
it's a test program for toggling a button this whole program except the headers
Humberto
PostPosted: Fri Nov 03, 2006 7:58 am     Reply with quote
The code posted by Mark should work.
What about your hardware:
does the uC oscillator is running ?
can you blink a LED to see that it is alive ?
can you write a single word in the LCD ?
did you connect pull up resistors in the push buttons ?
Humberto
Mark
PostPosted: Fri Nov 03, 2006 8:07 am     Reply with quote
Obivously then you do not want any help since you cannot do what is asked. I'm done....Bye
PostPosted: Fri Nov 03, 2006 8:11 am     Reply with quote
Humberto all thing is allright i can do anything with lcd the xtal is ok and the board is ok
Mark i can't understand you this is the main of my program so it's my whole program i use PIC 16F876A and 20 Mhz xtal anyway thanks .. Rolling Eyes
Mark
PostPosted: Fri Nov 03, 2006 9:25 am     Reply with quote
What can't you understand about posting a COMPLETE program that compiles. I don't want bits and pieces or psudeo code or even something typed out which is close to the test program. I want a cut and paste of your program. Is that clear enough? Did ya understand that? I've been at this quite a while and have wasted plenty of time because of other problems else where in the code.
PostPosted: Sat Nov 04, 2006 3:55 am     Reply with quote
Ok here's the Code
#include <16F876A.h>
#fuses XT,NOWDT
#use delay(clock=2000000)
#include "LCD.c"
while(true){
   static int  mm = 0;
   case 0:
   delay_ms(500); //Debounce
   case 1:
jecottrell
PostPosted: Sat Nov 04, 2006 4:45 am     Reply with quote
I don't think you're using the code that was written for you.
I don't follow your logic in using a SWITCH statement for an either/or condition?
Also:
20 Mhz xtal
That is one very good reason to post the WHOLE program.
If you'd like the pros to help you, let them.
PostPosted: Sat Nov 04, 2006 4:53 am     Reply with quote
jecottrell Thanks For Xtal note really i was working on the program without notice the xtal value
Thanks again but i use the same technique in Borland C++ Builder to perform two action with same button !! and here it's not working
jecottrell
PostPosted: Sat Nov 04, 2006 4:57 am     Reply with quote
You need to figure out what you're doing. Are you trying to get code working on a PIC or what?
If you're using a 20MHz crystal should also use the HS fuse and not the XT.
A 500mS debounce delay is too long also.
Make some effort here and give a detailed account of what you are doing. Otherwise you're going to on your own.
Goto page 1, 2  Next
Page 1 of 2
