Itīs possible LINUX in PIC
linux123
PostPosted: Fri Nov 03, 2006 1:44 pm     Reply with quote
Hy people.
Itīs possible install LINUX or FREE-BSD to load in MCU PIC ?
If possible, how version and model MCU minimun ?
Thanks.
dbotkin
PostPosted: Fri Nov 03, 2006 2:16 pm     Reply with quote
Nope.
jma_1
PostPosted: Fri Nov 03, 2006 2:21 pm     Reply with quote
Why would you try and put a complicated operating system on an 8-bit microprocessor? Simple task scheduler, finite state machine -> no problem. What would you gain with a full blown O.S (memory management, external resource manager, priority task scheduler, etc)?
Many forum readers would gladly (hopefully) help if you had a specific goal in mind of creating XXXX. For example, creating an application which would dynamically allow you to load new features/tasks through a serial port / flash memory / ethernet or ? would be a worth while project.
Cheers,
JMA
linux123
Very good...
PostPosted: Mon Nov 06, 2006 9:19 am     Reply with quote
I agree, i question for do, itīs possible, PIC with LINUX.
I job in project, creat one switch with 8 ports RJ-45 to controler status of interface remotely, i find a RTL8309SB to job, but i do not know conect my PIC with MII PHY mode from RTL8309SB, but i find routine to LINUX.
My project itīs complicade, this product it exists, but high price.
PostPosted: Mon Nov 06, 2006 11:20 am     Reply with quote
I'd really have to say that 'Linux' is not possible. However in the past, there were mini 'unix alike' OS's implemented on quite basic processors, which could probably be recoded onto a larger PIC. However it'd involve a hell of a lot of code. I'd guess at probably something like about six months of programming, to give a basic command prompt and file system.
Realistically, it'd be much cheaper to use a processor for which such a micro core is already available. Unless the sales are likely to be in the 100000 off or above area, the 'saving' from the use of a PIC, is not going to be worthwhile...
linux123
thanks
PostPosted: Mon Nov 06, 2006 12:34 pm     Reply with quote
Debtor, I go to try another solution.
