lozzik
| Cant write asm in correct adress |
Posted: Fri Nov 03, 2006 4:10 am |
i am using the PCWH 3,249
in my project there is some codes that have to be executet at startup before anything others. So i am writing it in the first letter in main function. But CCS generates some other codes before my code (defining variables etc.).
i have contactet with ccs support and they have said that i could it by using the #build, #org and #rom combination. i couldnt use the #rom and there is no examples in ccs
can anybody help me to execute my code before anything other.
Thanks an sorry for my english |
Posted: Fri Nov 03, 2006 5:00 am |
#build, is in the manual now. If you have an older compiler (before it was documented here), look in the compiler directory, for the 'readme.txt' file, which documents the 'extras'.
The key is that with this, you can move the start of the _CCS_ code to a point higher in memory. So if you have:
#build(reset=0x100)
CCS, will put _it's_ code, starting at address 0x100.
Then you would need to put your assembler at the bottom of memory, and end it with a jump to this address.
If you are using interrupts, you would need to either reloctate the handler for these as well, or 'jump round' this.
Have a look in the examples, for the bootloader stuff (ex_bootload.c). The bootloader is done, by having the bootloader code at the bottom of memory, where it is run first, and checks to see if particular conditions are met for it to start working. If not, the code then jumps to the relocated 'main' function. Hence the relocation involved, is exactly what you need to do.
Posted: Fri Nov 03, 2006 7:47 am |
i have looked the example bootloader.c
and i write my code so:
first
#build(reset=0x00020)
then
#org 0,10{} //this adresses will be reserwed by compiling
then
#org 0
a jump to my code that has to be executed first
at the end of my code there is a jump back to main
#org default
with this code i have still a problem
the code that has to be executet first runs without any problems but it doesnt jump to main everytime, it jumps sometimes that shows the adress is true but why not everytime.
in summary the code works sometimes how can this be possible |
Posted: Fri Nov 03, 2006 8:00 am |
Without seeing what your code is doing, this sounds like something in the addressing is wrong. Note that your 'org' statement, only allows enough space for five instructions in your code (10 != 0x10).
I'd suggest declaring as:
#build(reset=0x20)
#org 0,0x1F
void boot(void) {
#asm
//No 'jump' is needed. This code is at address 0
//Other code here as needed
goto 0x20
#endasm
#org default
Just one other comment. Some PICs, have a fault, that requires there is a NOP at address 0.
lozzik
Posted: Fri Nov 03, 2006 8:40 am |
here is my code
| Code: | #include <18f4620.h>
#fuses intrc,NOWDT,PROTECT,NOLVP,NOBROWNOUT,NOMCLR,NOPBADEN
#org 0,0x10 {}
void yaz(int i)
output_b(i);
output_high(PIN_A0);
delay_us(2);
output_low(PIN_A0);
#ORG 0
void jump_to_boot(void) //it jumps to boot program that has to be run first
delay_cycles(1);
goto_address(0x00066);
#ORG default
void boot(void)
int i;
for(i=3;i>0;i--)
yaz(1);
delay_ms(250);
yaz(0);
set_tris_b(0);
output_b(0);
set_tris_a(0x00);
output_low(PIN_A2);
goto_address(0x0009E); // jump to main
setup_oscillator(OSC_4MHZ);
delay_ms(20);
yaz(1);
delay_ms(250);
yaz(0);
boot();
and here is the list file
CCS PCH C Compiler, Version 3.249, 34456 03-Kas-06 16:33
Filename: C:\xxxx
ROM used: 192 bytes (0%)
Largest free fragment is 65316
RAM used: 5 (0%) at main() level
7 (0%) worst case
Stack: 3 worst case (2 in main + 1 for interrupts)
00020: GOTO 009E
.................... #include <18f4620.h>
.................... //////// Standard Header file for the PIC18F4620 device ////////////////
.................... #device PIC18F4620
.................... #list
.................... #fuses intrc,NOWDT,PROTECT,NOLVP,NOBROWNOUT,NOMCLR,NOPBADEN
.................... #build(reset=0x00020)
.................... #org 0,0x10 {}
.................... #use delay(clock=4000000)
00028: CLRF FEA
0002A: MOVLW 07
0002C: MOVWF FE9
0002E: MOVF FEF,W
00030: BZ 0050
00032: MOVLW 01
00034: MOVWF 01
00036: CLRF 00
00038: DECFSZ 00,F
0003A: BRA 0038
0003C: DECFSZ 01,F
0003E: BRA 0036
00040: MOVLW 4A
00042: MOVWF 00
00044: DECFSZ 00,F
00046: BRA 0044
00048: NOP
0004A: NOP
0004C: DECFSZ FEF,F
0004E: BRA 0032
00050: RETLW 00
.................... void yaz(int i)
.................... output_b(i);
00052: CLRF F93
00054: MOVFF 07,F8A
.................... output_high(PIN_A0);
00058: BCF F92.0
0005A: BSF F89.0
.................... delay_us(2);
0005C: NOP
0005E: NOP
.................... output_low(PIN_A0);
00060: BCF F92.0
00062: BCF F89.0
00064: RETLW 00
.................... #ORG 0
.................... void jump_to_boot(void) //it jumps to boot program that has to be run first
.................... delay_cycles(1);
00000: NOP
.................... goto_address(0x00066);
00002: GOTO 0066
00006: RETLW 00
.................... #ORG default
.................... void boot(void)
.................... int i;
.................... for(i=3;i>0;i--)
00066: MOVLW 03
00068: MOVWF 06
0006A: MOVF 06,F
0006C: BZ 0088
.................... yaz(1);
0006E: MOVLW 01
00070: MOVWF 07
00072: RCALL 0052
.................... delay_ms(250);
00074: MOVLW FA
00076: MOVWF 07
00078: RCALL 0028
.................... yaz(0);
0007A: CLRF 07
0007C: RCALL 0052
.................... delay_ms(100);
0007E: MOVLW 64
00080: MOVWF 07
00082: RCALL 0028
00084: DECF 06,F
00086: BRA 006A
.................... set_tris_b(0);
00088: MOVLW 00
0008A: MOVWF F93
.................... output_b(0);
0008C: CLRF F93
0008E: CLRF F8A
.................... set_tris_a(0x00);
00090: MOVWF F92
.................... output_low(PIN_A2);
00092: BCF F92.2
00094: BCF F89.2
.................... goto_address(0x0009E); // jump to main
00096: GOTO 009E
0009A: GOTO 00DA (RETURN)
0009E: CLRF FF8
000A0: BCF FD0.7
000A2: CLRF FEA
000A4: CLRF FE9
000A6: MOVLW 60
000A8: MOVWF FD3
000AA: MOVF FC1,W
000AC: ANDLW C0
000AE: IORLW 0F
000B0: MOVWF FC1
000B2: MOVLW 07
000B4: MOVWF FB4
.................... setup_oscillator(OSC_4MHZ);
000B6: MOVLW 60
000B8: MOVWF FD3
.................... delay_ms(20);
000BA: MOVLW 14
000BC: MOVWF 07
000BE: RCALL 0028
.................... while(1)
000C0: MOVLW 01
000C2: MOVWF 07
000C4: RCALL 0052
000C6: MOVLW FA
000C8: MOVWF 07
000CA: RCALL 0028
000CC: CLRF 07
000CE: RCALL 0052
000D0: MOVLW 64
000D2: MOVWF 07
000D4: RCALL 0028
000D6: BRA 00C0
.................... boot();
000D8: BRA 0066
000DA: SLEEP
Configuration Fuses:
Word 1: 0900 NOIESO INTRC NOFCMEN RESERVED
Word 2: 1E19 NOBROWNOUT NOWDT BORV21 NOPUT WDT32768
Word 3: 0100 CCP2C1 NOPBADEN NOLPT1OSC NOMCLR RESERVED
Word 4: 0081 STVREN NODEBUG NOLVP NOXINST RESERVED
Word 5: C000 PROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
with this code if i run the circuit first it doesnt works (i mean the boot program runs and it doesnt return to main) after a reset both are working how can this possible
thanks |
Posted: Fri Nov 03, 2006 9:11 am |
You are doing so much jumping around, that it is hard to work out what the implications are. I'd suggest tidying things a lot. You do not need two sets of org statements. Use something like this:
#build(reset=0x10)
void yaz(int i); //prototype for yaz
void boot(void); //prototype for boot
#ORG 0,0xF
//Place at bottom of memory. It jumps to boot program that has to be run first
void jump_to_boot(void) {
delay_cycles(1);
boot();
goto_address(0x10);
#org default
//Now everything else, wants normal definitions
void boot(void) {
int i;
for(i=3;i>0;i--) {
yaz(1);
delay_ms(250);
yaz(0);
set_tris_b(0);
output_b(0);
set_tris_a(0x00);
output_low(PIN_A2);
//goto_address(0x040); // jump to main
//Do _not_ do this. This is fine if 'boot' is only used from the boot,
//but since you also call it from the main, will result in a stack overflow
//Let the code return,and handle this in the loader.
void yaz(int i) {
output_b(i);
delay_us(2);
output_low(PIN_A0);
void main(void) {
delay_ms(20);
yaz(1);
delay_ms(250);
yaz(0);
boot();
lozzik
Posted: Fri Nov 03, 2006 9:41 am |
Thank you for your repleys.
This code is much easier than the first.
I have written this one. But i have still the same problem. I cant understand how this can happen code works sometimes and somtimes not.
I am swtiching the circuit on everything is okey the boot program runs then it returns to main. I am switching the circuit off starting again this time the boot program runs again but it doesnt returns to main.
i am gonna try with different adresses and different pic. |
lozzik
Posted: Fri Nov 03, 2006 9:51 am |
here is the reply from ccs support
do you now using the #rom directive
| Quote: | 1. Use #BUILD( reset=xxxx ) to put the compilers jump to
main at some new place in memory (like 0x100).
2. Create a function with your code in it. At the end of this
function do a GOTO_ADDRESS(xxxx) and use #ORG to
fix this function at some address (yyyy).
3. Use #ROM 0={...} to insert a GOTO instruction at location 0
to jump to yyyy. You could do this in C with a #org'ed function
but make sure it does not run into the interrupt vector. |
thanks again. |
Posted: Fri Nov 03, 2006 11:04 am |
Read what they say again.
You will see that they say you can do the jump using #org, _or_ #rom. The 'danger' with the ORG approach, is that if you have interrupt vectors in use (remember I asked this, and your sample code does not show this), it uses an extra instruction for the 'return' at the end of the ORG'd function, and this can clash with interrupt vectors. You do not need the ROM approach.
ROM, simply allows you to define individual bytes/words to be written to a particular memory location.
You couldn't use the ROM approach easily, since you are doing something they did not expect, and wanting to call the same routine again inside the main code. This _requires_ the extra return instruction is present...
Seriously, the code as posted works (I checked it did, before I posted it). The behaviour you are seeing is something to do with the enviroment you are testing it in.
lozzik
Posted: Sat Nov 04, 2006 1:28 am |
@Ttelmah
Thank you again for your replys |
