eeprom read -16f690
Goto page 1, 2  Next
vinu
eeprom read -16f690
PostPosted: Tue Aug 22, 2006 5:17 am     Reply with quote
Dear Sir,
is the command "read_eeprom(8-bit address)" work well for 16F690 IC?. I have problems with this particular IC. But the code work well for other IC's like 16F877A. is there any differece in reading eeprom values in 16F690 using CCSC.
Regards,
Vineesh.A
Fabri
PostPosted: Tue Aug 22, 2006 9:45 am     Reply with quote
HI Vinu,
The problem, I belive is in configuration memory of device by compiler.
I had the same problem with PCWH V3,235 and PIC16F628 & PIC16F690.
You have to change with device editor the Data EE Type in Memory configuration. you have to change it to normal.
Bye,
vinu
eeprom read -16f690
PostPosted: Tue Aug 22, 2006 9:52 pm     Reply with quote
Thanks for the valueble information. going to try .
Regards,
vinu
banic
eeprom read
PostPosted: Fri Nov 03, 2006 6:54 am     Reply with quote
Hello
What is device editor?
Tanks Banic
Fabri
PostPosted: Fri Nov 03, 2006 7:03 am     Reply with quote
With device editor you can give some information to your compiler as memory organization, ram, eeprom e so on.
You can found it under "TOOLS" section of compiler IDE.
Regards,
Re: eeprom read
banic wrote:
Hello
Thanks Banic
BANIC
EEPROM
PostPosted: Fri Nov 03, 2006 7:06 am     Reply with quote
Hello
I use MPLAB IDE.
Thanks Banic
Fabri
PostPosted: Fri Nov 03, 2006 7:10 am     Reply with quote
In any case the CCS compiler use configuration wrote in device editor.
I'm also use MPLAB.
Regards,
banic
eeprom
PostPosted: Fri Nov 03, 2006 7:30 am     Reply with quote
Hello
Sorry. Not very clear. What program to run? Which button in MPLAB to push?
Thanks Banic
Fabri
PostPosted: Fri Nov 03, 2006 7:57 am     Reply with quote
I'm sorry but English is not my language and I can't explain you as I want.
CCS compiler has it's IDE but you can use the compiler directly with MPLAB, as I do.
PCW Compiler IDE start with file "Pcw.exe".
Which version of CCS compiler have you got ?
Regards,
BANIC
eeprom
PostPosted: Fri Nov 03, 2006 8:33 am     Reply with quote
Hello
I am not a native english. I have not got CCS IDE. I included it in MPLAB.
Still not clear.
Thanks Brano
Fabri
PostPosted: Fri Nov 03, 2006 9:13 am     Reply with quote
In the latest MPLAB V7.41 there is a free CCS PCB compiler.
I' can't help you because, at the moment I use MPLAB V7.40 with full version of CCS compiler.
Take a look in help file inside MPLAB
Regards,
dyeatman
PostPosted: Fri Nov 03, 2006 11:07 am     Reply with quote
Unless you have CCS version PCW or PCWH you will NOT have the Device editor. It is ONLY available with the CCS PCW/PCWH IDE and NOT through MPLAB.
Banic
eeprom
PostPosted: Mon Nov 06, 2006 1:04 am     Reply with quote
Hello
Could someone send me repaired device file related to the eeprom problem?
Thanks b_banic@post.sk
BANIC
eeprom
PostPosted: Mon Nov 06, 2006 8:01 am     Reply with quote
Hello
I have forgotten the compiler version: PCM 3.225.
Thanks Banic
Goto page 1, 2  Next
Page 1 of 2
