range of byte
byatin
range of byte
PostPosted: Mon Oct 30, 2006 3:18 am     Reply with quote
hi,does anybody knows ,what is the range of byte,is it the same as int8.
and can we specify whether a variable is signed or unsigned such as
unsigned char and signed char.
jecottrell
PostPosted: Mon Oct 30, 2006 5:11 am     Reply with quote
A byte is a byte is a byte. If you're unsure look at the includes that define it an see how exactly how it is defined....
From the manual:
Basic Types
Type-Specifier
int1 Defines a 1 bit number
int8 Defines an 8 bit number
int16 Defines a 16 bit number
int32 Defines a 32 bit number
char Defines a 8 bit character
float Defines a 32 bit floating point number
short By default the same as int1
Int By default the same as int8
long By default the same as int16
void Indicates no specific type
Note: All types, except float, by default are unsigned; however, maybe preceded by unsigned or
signed.
Short and long may have the keyword INT following them with no effect. Also see #TYPE
to change the default size.
