byatin
needed file ds1307.c |
Posted: Sat Oct 28, 2006 3:15 am |
hi,i have read a source code for ds1307.c given in the code library
and there a file is included ds1307.c , i am using the CCS Compiler PCWH
with version 3.245 and it does not contain this file in the drivers section,
if anybody having this file ,then please post me as a reply here. |
Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
byatin
Posted: Sat Oct 28, 2006 4:44 am |
hi storic ,i read the reply ,you have posted ,actually i got the driver for ds1307 , which is given below, but in this there is a file included ds1307.c in the example code, i actually need that file because in my compiler there is a file ds1305.c , but not ds1307.c
can you please read the code, actually i think that the file ds1307.c is not required ,what do you think about it.
/// DS1307.C ///
/// Driver for Real Time Clock ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
/// used when PIC loses power and DS1307 run from 3V BAT ///
/// - Disable squarewave output ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec) Set the date/time ///
/// ds1307_get_date(day,mth,year,dow) Get the date ///
/// ds1307_get_time(hr,min,sec) Get the time ///
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // Control Register
i2c_write(0x80); // Disable squarewave output pin
i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0); // I2C write address
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_write(bin2bcd(sec)); // REG 0
i2c_write(bin2bcd(min)); // REG 1
i2c_write(bin2bcd(hr)); // REG 2
i2c_write(bin2bcd(dow)); // REG 3
i2c_write(bin2bcd(day)); // REG 4
i2c_write(bin2bcd(mth)); // REG 5
i2c_write(bin2bcd(year)); // REG 6
i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
i2c_start();
i2c_write(0xD0);
i2c_write(0x03); // Start at REG 3 - Day of week
i2c_start();
i2c_write(0xD1);
dow = bcd2bin(i2c_read() & 0x7f); // REG 3
day = bcd2bin(i2c_read() & 0x3f); // REG 4
mth = bcd2bin(i2c_read() & 0x1f); // REG 5
year = bcd2bin(i2c_read(0)); // REG 6
i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f);
min = bcd2bin(i2c_read() & 0x7f);
hr = bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
BYTE temp;
BYTE retval;
temp = binary_value;
retval = 0;
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// Input range - 00 to 99.
BYTE temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
Example use:
#include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use delay(clock=20000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PC,errors)
#include <ds1307.c>
BYTE sec;
BYTE min;
BYTE hrs;
BYTE day;
BYTE month;
BYTE yr;
BYTE dow;
ds1307_init();
// Set date for -> 15 June 2005 Tuesday
// Set time for -> 15:20:55
ds1307_set_date_time(15,6,5,2,15,20,55);
ds1307_get_date(day,month,yr,dow);
ds1307_get_time(hrs,min,sec);
printf("\f\%02d/\%02d/\%02d\r\n",day,month,yr);
printf("\%02d:\%02d:\%02d", hrs,min,sec);
Storic
Posted: Sat Oct 28, 2006 6:41 am |
http://www.rentron.com/CCS_C/SERLED_C.htm has circuits and a whole lot of code.
I dont have ds1307.c driver
Andrew _________________ What has been learnt if you make the same mistake? ![Wink](images/smiles/icon_wink.gif) |
Mark
Re: needed file ds1307.c |
Posted: Sat Oct 28, 2006 9:06 am |
What do you think this is that you posted!
byatin wrote: |
/// DS1307.C ///
BYTE seconds = 0;
i2c_start();
i2c_start();
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_start();
i2c_stop();
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_stop();
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
i2c_stop();
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
i2c_stop();
BYTE temp;
BYTE retval;
retval = 0;
if(temp >= 10)
temp -= 10;
retval += 0x10;
retval += temp;
return(retval);
BYTE temp;
temp = bcd_value;
temp >>= 1;
temp &= 0x78;
