Force a 16 pointer to struct
treitmey
PostPosted: Fri Oct 27, 2006 12:10 pm     Reply with quote
When the *=16 is commented out this works. but with the 16bit pointers
I thought the compiler would take care of the char* using 16bit.
The base pointer in init is only 8bit not the required 16bit.
Can I make this work? ((Force/typecast it))
I am using 3.249
#include <16F877A.h>
#device *=16
#fuses hs,nowdt,noprotect,nolvp,put
#use delay(clock=11059200)
#use rs232(baud=19200,xmit=PIN_E2,invert,stream=debug,disable_ints)
#case
#zero_ram
struct buf {
   char *bas;
   char *in;
   char *out;
   int8 len;
   char ctl;
struct buf tbctl;
#define TBLEN   32
char  txbuf[TBLEN];
void init_buf();
void init_buf_ctl(struct buf *ctl, char *base, int length);
signed int8 cbw(char data, struct buf *ctl);
signed int8 cbr(struct buf *ctl);
//=== MAIN ===//
  fprintf(DEBUG,"Start\n\r");
  txbuf[0]=0xAA;
  fprintf(DEBUG,"set txbuf[0]=0x%X\n\r",txbuf[0]);
  fprintf(DEBUG,"addr txbuf[0]=0x%lX\n\r",&txbuf[0]);
  init_buf();
  cbw(0xBB, &tbctl);
  fprintf(DEBUG,"now txbuf[0]=0x%X\n\r",txbuf[0]);
void init_buf()
   init_buf_ctl(&tbctl, txbuf, sizeof(txbuf));
/* Initialize Buffer Control Block. */
  fprintf(DEBUG,"base here=0x%lX\n\r",base);
   ctl->bas = base;
   ctl->in  = base;
   ctl->out = base;
   ctl->len = length;
   ctl->ctl = 0;
/* Circular Buffer Write. */
   *ctl->in++ = data;
   return 1;
///* Circular Buffer Read. */
//signed int8 cbr(struct buf *ctl)
//   int data;
//   data = *ctl->out++;
//   return data;
PostPosted: Fri Oct 27, 2006 12:36 pm     Reply with quote
Can you post the results you expect to see, and post the results that
you're getting ? (The print out from the Debug stream).
treitmey
PostPosted: Fri Oct 27, 2006 12:59 pm     Reply with quote
First run is with the =*16 commented out
next is with it in. The base should be 0x2A29 in second run.
Start
set txbuf[0]=0xAA
addr txbuf[0]=0x26
base here=0x26
now txbuf[0]=0xBB
Start
set txbuf[0]=0xAA
addr txbuf[0]=0x2A29
base here=0x0029
now txbuf[0]=0xAA
PostPosted: Fri Oct 27, 2006 1:22 pm     Reply with quote
The highest available RAM address in a 16F877A is 0x1FF. That's at
the end of bank 3. Buts that's in the common ram area, which is not
normally used for user variables. The array is 32 bytes long, so the
highest base address the compiler would assign to it is 0x01D0.
It can't ever be 0x2A29.
treitmey
PostPosted: Fri Oct 27, 2006 1:33 pm     Reply with quote
Right, Right,Right,
So.... Is the printf STATEMENT wrong or the printf funtionality?
Printf functionality..
#device *=16
#case
#zero_ram
#define TBLEN   90
char  txbuf[TBLEN];
//=== MAIN ===//
  int16 addr;
  txbuf[0]=0xAA;
  addr=&txbuf[0];
  fprintf(DEBUG,"addr =0x%lX\n\r",addr);
Start
set txbuf[0]=0xAA
addr txbuf[0]=0x1110
addr =0x0110
treitmey
PostPosted: Fri Oct 27, 2006 1:44 pm     Reply with quote
So the fault in in the ++ increment and *=16
This works
   *ctl->in=data;
   ctl->in++;
   return 1;
This fails
   *ctl->in++=data;
   return 1;
PostPosted: Fri Oct 27, 2006 1:49 pm     Reply with quote
It looks like a printf bug. It can't extract the address correctly.
printf("addr txbuf[0] = %lx \n\r", txbuf);
0072 3011       00438 MOVLW  11  // Bug -- MSB should be 01.
0073 00ED       00439 MOVWF  6D
0074 3057       00440 MOVLW  57
0075 00EE       00441 MOVWF  6E
0076 1303       00442 BCF    03.6
0077 201F       00443 CALL   01F
0078 3010       00444 MOVLW  10   // LSB is correct.
0079 1703       00445 BSF    03.6
007A 00ED       00446 MOVWF  6D
007B 3057       00447 MOVLW  57
007C 00EE       00448 MOVWF  6E
007D 1303       00449 BCF    03.6
007E 201F       00450 CALL   01F
PostPosted: Fri Oct 27, 2006 3:48 pm     Reply with quote
This fails:
*ctl->in++=data;
return 1;
I did some testing and it works in MSVC vs. 1.52, but it fails in CCS.
This was with PCM vs. 3.249.
I tried to come up with a fix by putting in parentheses, but
it didn't help. I think you have to split the code into two lines
as you have done, as a work-around.
treitmey
PostPosted: Mon Oct 30, 2006 9:52 am     Reply with quote
Cool
Thanks for your time.
