Problems with bank change.
carlos.e.carvalho
PostPosted: Thu Oct 26, 2006 2:18 pm     Reply with quote
I have some problems with my code when it exceeds 50% of ROM. The program stops and I don't know what to do. I am using a PIC16F685 and CCS compiler V4.013
PostPosted: Thu Oct 26, 2006 2:21 pm     Reply with quote
Download vs. 3.249 and install it.
http://www.ccsinfo.com/compilerupdates.php
carlos.e.carvalho
Problems with compiler
PostPosted: Fri Oct 27, 2006 12:23 pm     Reply with quote
We are testing your compiler with PIC16F685 and PIC16F684 which was given with a 30 days trial after a contact with your comercial department. For this project we need a best compression to use the less expensive PIC.
The compiler is PCM Compiler 4.013.
When we compile our program and it reaches a ROM space higher than 50%, the processor 16F685 stop running. If we hide some lines and the ROM became lower than 50% it run normally.
I tried to use the #SEPARATE command before some functions without success. The Watchdog is disable in configuration bits.
Thanks a lot,
Carlos
PostPosted: Fri Oct 27, 2006 12:34 pm     Reply with quote
From the CCS support page:
User Forums
We have setup a message forum set up for CCS C customers to
exchange ideas and thoughts.
Everyone on this forum is a CCS customer or user (except Darren Rook).
You should send an email to CCS tech support. See this page:
http://www.ccsinfo.com/content.php?page=techsupport
