16C745 and USB HID Report
dukelc4
PostPosted: Thu Oct 26, 2006 8:23 am     Reply with quote
i use the PIC 16C745 to communicate with a PC
over USB. It works fine.
In the moment i use the USB Hid Files from CCS.
In the HID Report of these source is described that
the pic should recieve and send 2 bytes from 0 to 0xff.
But i don`t need to send bytes to the pc,
i only want to recieve bytes.
Does anyone know what i have to change in the HID Report?
     BYTE CONST USB_HID_DESC[] = {  //len=28
      6, 0, 255,    // Usage Page = Vendor Defined
      9, 1,            // Usage = IO device
      0xa1, 1,       // Collection = Application
      0x19, 1,        // Usage minimum
      0x29, 8,        // Usage maximum
      0x15, 0x80,        // Logical minimum (-128)
      0x25, 0x7F,        // Logical maximum (127)
      0x75, 8,        // Report size = 8 (bits)
      0x95, 2,        // Report count = 16 bits (2 bytes)
      0x81, 2,        // Input (Data, Var, Abs)
      0x91, 2,        // Output (Data, Var, Abs)
      0xc0            // End Collection
[/code]
