Optimised ways to call functions?
alanp
PostPosted: Wed Oct 25, 2006 5:44 pm     Reply with quote
I'm after some help trying to convert some code from the HiTech C compiler to the CCS.
The code has been optimised to do things between interrupts so there is a mixture of both C and asm.
The HiTech compiler uses the W register to move information to and from functions. Thus the code is very compact. For example to get something from the EEPROM and send it, the eep_read function has been optimised in asm so it doesn't have to return a value (because it is already in the W register). This listing is from the .LST file:
   924                           403: sendc(eep_read(0x1f));
   925  0477  301F                  movlw   31
   926  0478  1283                  bcf   3,5
   927  0479  21BD                  call   _eep_read
   928  047A  22FB                  call   _sendc
   231                           char eep_read(char addr)
   232                           {
   233  01BD                     _eep_read
   234                           TMR0IE = 0;
   235  01BD  128B                  bcf   11,5
   236  01BE  1683                  bsf   3,5   ;Bank 1
   237  01BF  009B                  movwf   27   ;W contains the address to read
   238  01C0  141C                  bsf   28,0   ;Read EE
   239  01C1  081A                  movf   26,w   ;Move data to W
   240                           TMR0IE = 1;
   241  01C2  168B                  bsf   11,5
   242                           }
   243  01C3  1283                  bcf   3,5
   244  01C4  0008                  return
A similar call in CCS is shown below:
....................       sendc(eep_read(0x1f));
02D1:  MOVLW  1F
02D2:  MOVWF  5F
02D3:  CALL   0C9
02D4:  MOVF   21,W
02D5:  MOVWF  5E
02D6:  MOVWF  60
02D7:  CALL   132
.................... char eep_read(char addr)
....................    char ret;
....................    TMR0IE = 0;
00C9:  BCF    0B.5
....................    ret = read_eeprom(addr);
00CA:  MOVF   5F,W
00CB:  BSF    03.5
00CC:  MOVWF  1B
00CD:  BCF    1C.7
00CE:  BSF    1C.0
00CF:  MOVF   1A,W
00D0:  BCF    03.5
00D1:  MOVWF  60
....................    TMR0IE = 1;
00D2:  BSF    0B.5
....................    return (ret);
00D3:  MOVF   60,W
00D4:  MOVWF  21
00D5:  RETLW  00
The CCS compiler moves all the variables to RAM before calling the function. The function then has to get the variables out of RAM, put the result back into RAM, and then read from RAM when back in the main function.
There are 12 instructions for the HiTech compilers and 20 for CCS, with a little more tinkering I could reduce the CCS by a couple. With would still leave an extra 50% with CCS.
Does anybody use any techniques that would allow functions to be called in a more effiecent way??
Many thanks
alanp
PostPosted: Thu Oct 26, 2006 1:04 am     Reply with quote
I don't think there's any way to force the compiler to optimize the
code to use the W register instead of RAM, to pass and return a
single byte value.
What PIC are you using ? I'm not able to duplicate your code
unless I know that.
PostPosted: Thu Oct 26, 2006 2:09 am     Reply with quote
Thanks for the reply PCM Programmer,
At the moment I'm using the 16F636.
While I understand that I could put the function in-line, I would rather not because of space.
I wasn't really expecting a positive outcome because of the way the CCS compiler works.
PostPosted: Thu Oct 26, 2006 2:31 am     Reply with quote
By passing and returning everything in a global variable, I was able
to reduce the eeprom function by 2 ROM words. Not very much.
