Copy data External EEpprom
Orcino
PostPosted: Mon Oct 23, 2006 1:46 pm     Reply with quote
Hi, I have a 200 var int32 in a 24LC256, i need to copy for the memory RAM in " INT32 BUFFER_COORD[200] ". Which the best way ?
Thanks in advanced
Orcino
PostPosted: Mon Oct 23, 2006 2:34 pm     Reply with quote
Read four bytes from the eeprom, in sequence. Put each byte in
a temporary variable in your C program. Then use the make32()
function to combine the four temporary variables into one 32-bit
value. Put the result of make()32 into one element of your
Buffer_Coord[] array. Create a for() loop that will execute 200 times
and repeat the above process until you have filled the array.
See the CCS manual for a description of the make32() function.
