Pointer to a string table
Alexei
PostPosted: Mon Oct 23, 2006 9:12 am     Reply with quote
hello, I use PICC 3.202 for PIC16F877A
I have a problem, the compiler don't want to recognize the following construction:
const char* const message_lcd[] =
   " FONCTIONNEMENT     MODE PC     ",   //0
   "TEST ETANCHEITE MASQUE          ",   //1      MESSAGES "TEST ETANCHEITE MASQUE"
   "-",                        //2
   " mbar      DEGONFLER       ",      //3
   " mbar      REGONFLER       ",      //4
   " mbar      APPUYER SUR <E> ",      //5
I tried to use
char const message[][]=
   "-",                        //2
it doesn't work. can anyone help me? I want to put in RAM a string table and I can't do it.
Alexei
PostPosted: Mon Oct 23, 2006 9:14 am     Reply with quote
sorry, I want to put a string table not in RAM but in ROM.
Neckruin
PostPosted: Mon Oct 23, 2006 10:04 am     Reply with quote
I have also tried to allocate a bidimensional array in ROM but wasn't able to do it Sad
I finally used single arrays.
I hope somebody can help you (or "us")
Good Luck,
Juanma
PostPosted: Mon Oct 23, 2006 10:50 am     Reply with quote
The program shown below works OK. It displays the following output.
 mbar      DEGONFLER
 mbar      REGONFLER
Here is the program. It was tested with PCH vs. 3.249.
#include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP, NOPROTECT, CPB
char const message[6][33]=
   "-",                        //2
int8 i;
for(i = 0; i < 6; i++)
    printf("%s\n\r", message[i]);
Mark Weir
Question
PostPosted: Tue Oct 24, 2006 5:53 pm     Reply with quote
My question is really to PCM. I have tried the piece of code you supplied in answer to this post and of course it works well. Could you please tell me about the range of the two parameters. This setup has 6 messages of up to 33 characters if I understand correctly. If I want to have 20 messages, say, will they have to be shorter or can the range be extended?
Cheers
Mark
PostPosted: Tue Oct 24, 2006 10:21 pm     Reply with quote
For the PCM compiler, the size limit is 256 bytes for a ROM array.
For the PCH compiler, it's much larger. I don't know what the limit is
because I haven't run up against it yet. It works with at least 1KB.
