canīt use LCD with a 18F6720
PostPosted: Fri Oct 20, 2006 11:57 am     Reply with quote
The include file 18F6720.h does not include any function for using LCD
Look in the driver directory for the compiler:
c:\Program Files\Picc\Drivers
Look in the Code Library forum:
http://www.ccsinfo.com/forum/viewforum.php?f=2
There are several LCD drivers in each one of those places.
LITTLE JON
PostPosted: Mon Oct 23, 2006 4:44 am     Reply with quote
We've found drivers for other PICs, such as 16Csomething, but the one for the 18F6720 does not support LCD
When compiling one of the examples (made for a 16C PIC) appear several errors. Is there any example program which supports LCD with a 18F6720??
THANX FOR THE REPLY
PostPosted: Mon Oct 23, 2006 6:42 am     Reply with quote
The standard LCD driver, will run with the 8720 fine. None of the drivers are that 'device specific', except for things like the USB ones.
You need to set the configurations to use port B, or port D as required by yourself, and it will work fine.
