Where are constants allocated depending on how you use them?
Neckruin
PostPosted: Fri Oct 20, 2006 6:04 am     Reply with quote
Hello All,
I have a little little question.
Let's imagine this two pieces of code:
printf(lcd_putc, "THIS IS A CONSTANT STRING");
const char String[] = "THIS IS A CONSTANT STRING";
printf(lcd_putc, "%s", String);
The result will be the same but, in the second case I'm sure the string will be allocated in Program Memory, but... where is the string allocated in the first case????
Thanks in advance,
Juanma
PostPosted: Fri Oct 20, 2006 9:48 am     Reply with quote
Exactly the same way.
Best Wishes.
Neckruin
PostPosted: Mon Oct 23, 2006 1:10 am     Reply with quote
THANKS A LOT!!!! Very Happy
