Void pointer to different variable types.
Jim Hearne
PostPosted: Fri Oct 20, 2006 10:00 am     Reply with quote
Hi All,
I'm having trouble using a pointer to change different variable types, the code below (cut down from 30k's worth) shows the problem.
It works with 8 bit variables but not 16 (not shown) or 32 bit.
I'm probably doing something very silly, please put me out of my misery.
Thanks,
Jim Hearne.
#include <18f458.h>
#device  adc=10 *=16
#device  ICD=true
#include <STDLIB>
#use   delay(clock=20000000,RESTART_WDT)
#fuses NOWDT, WDT128, HS, PROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, STVREN, NODEBUG
#fuses NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
struct
int8  thingy1;
int32 thingy2;
} stuff;
typedef struct data_entry_struct
   int8  message[16];                       // Message on display
   int8  entry_method;                      // data_entry method
   int8  var_size;                          // var size in bytes(1=int8,2=16,4=32 etc)
   void  *var_ptr;                          // pointer to number location, cast to correct type later using var type
   int8  dp;                                // position of DP on display
   int8  units;                             // units to display after value, ms etc
   int32 min;                               // minimum value
   int32 max;                               // maximum value
const struct data_entry_struct const data_entry[2]=
//   message         entry method,     var size               var               dp    units    min   max
   {"Enter thingy1", 1           ,     sizeof(stuff.thingy1), &stuff.thingy1,   2,    0,       0,    100},
   {"Enter thingy2", 2           ,     sizeof(stuff.thingy2), &stuff.thingy2,   0,    0,       0,    10000},
int32 temp_data;
int8  data_index;
int8 data_byte_size;
stuff.thingy1=123;
stuff.thingy2=12345;
// loads of code here
data_index=1;  // this is normally set in the code
temp_data=(int32)*data_entry[data_index].var_ptr; // get variable value, this works fine
// code to change temp_data here
data_byte_size=data_entry[data_index].var_size;
// now put value back in variable according to size
if(data_byte_size==1)
   *(int8)data_entry[data_index].var_ptr=(int8)temp_data; // this works
else if(data_byte_size==4)
   *(int32)data_entry[data_index].var_ptr=temp_data; // this doesn't work, only writes low byte
// more code here
PostPosted: Fri Oct 20, 2006 11:31 am     Reply with quote
You need to tell the compiler that 'var_ptr' is a pointer to a 32-bit value.
You have this:
*(int32)data_entry[data_index].var_ptr = temp_data;
Change it to this:
*(int32 *)data_entry[data_index].var_ptr = temp_data;
The line for the 8-bit one should also be changed. It should be:
*(int8 *)data_entry[data_index].var_ptr = (int8)temp_data;
Jim Hearne
PostPosted: Fri Oct 20, 2006 1:31 pm     Reply with quote
Many thanks PCM for that quick fix, i knew it was something silly, i was close.
Thinking about it on the way home from work i think i need to cast the pointer for the variable read as well as it's probably reading 32 bits at the moment and only seems to be working because most of the variables are 0.
Despite programming with CCS for the last 4 years and Borland C for many years before that i still have trouble getting my head more complex pointer usage.
Has anybody got any pointers Smile to some good reading on the subject.
Most stuff now seems to be more related to c++ and windows programming and that confuses me even more.
Many thanks,
Jim Hearne
PostPosted: Fri Oct 20, 2006 1:53 pm     Reply with quote
Here's an explanation of the C language that's written in an
engineer to engineer" style. It might be helpful.
http://cslibrary.stanford.edu/101/EssentialC.pdf
