Read BCD Value on MSB of Port B
whmeade10
PostPosted: Fri Aug 08, 2003 7:17 am     Reply with quote
I have connected a 10 position BCD rotary switch to B4-B7 and
need to be able to place the value into a variable. When I
programmed in PIC Basic Pro this was pretty straight forward:
BCD_In = PORTB & \%11110000 ' Read BCD switch on ports B4-B7
I haven't been able to find anything simular in PIC-C.
Thanks in advance..
___________________________
Original Post ID: 144516813
Cinko
Re: Read BCD Value on MSB of Port B
PostPosted: Fri Aug 08, 2003 7:37 am     Reply with quote
:=I have connected a 10 position BCD rotary switch to B4-B7 and
:=need to be able to place the value into a variable. When I
:=programmed in PIC Basic Pro this was pretty straight forward:
:=BCD_In = PORTB & \%11110000 ' Read BCD switch on ports B4-B7
:=I haven't been able to find anything simular in PIC-C.
:=Thanks in advance..
Everything you have to do is:
1 - First declare PORTB
#byte PORTB = the actual portb addr
2 - Read the port to the variable
BCD_In = PORTB & 0xf0
That's it.
Original Post ID: 144516815
Cinko
PostPosted: Fri Aug 08, 2003 7:59 am     Reply with quote
Willian.
That's it.
Original Post ID: 144516818
whmeade10
PostPosted: Fri Aug 08, 2003 8:57 am     Reply with quote
Thanks for the quick response. It is easy.
I wuld also like to appoligize for all the multiple posts on this subject. I kept getting server error pages when submitting my question. I guess they went through even though I got an error. I also noticed that I can't view some of the replies to my questions.
:=:=I have connected a 10 position BCD rotary switch to B4-B7 and
:=:=need to be able to place the value into a variable. When I
:=:=programmed in PIC Basic Pro this was pretty straight forward:
:=:=BCD_In = PORTB & \%11110000 ' Read BCD switch on ports B4-B7
:=:=I haven't been able to find anything simular in PIC-C.
:=:=Thanks in advance..
:=Everything you have to do is:
:=1 - First declare PORTB
:= #byte PORTB = the actual portb addr
:=2 - Read the port to the variable
:= BCD_In = PORTB & 0xf0
:=That's it.
Original Post ID: 144516821
