two DS18s20 (indoor and outdoor)
linux123
PostPosted: Mon Oct 16, 2006 4:58 pm     Reply with quote
Hy, i need check two temps, indoor and outdoor, i use DS1820, from Dallas, the protocol is 1-wire, whats read two sensor ?
My MCU is 18F452.
Thanks.
LazBoy
PostPosted: Tue Oct 17, 2006 5:35 am     Reply with quote
This is my solution. I know, not a optimal solution but it works.
I modified this code from http://www.vermontficks.org/pic.htm (Jon Fick)
This is working code but a litlle slow communication:
You may decide seperate 2 pin for Indoor and Outdoor sensors.
Include this two sensor files to your project:
Variables:
#define DS1820_SKIP_ROM 0xCC
#define DS1820_READ_SCRATCHPAD 0xBE
#define DS1820_CONVERT_T 0x44
#define INDOOR_PIN    PIN_A0
#define OUTDOOR_PIN    PIN_A1
static char cShiftBit,cDataOut;
static long iTemperature,iDataIn;
indoor.c
///////////// INDOOR ///////////////////////
void ResetDS1820_Indoor( void )
    output_low ( INDOOR_PIN );
    delay_us ( 480 );
    output_float ( INDOOR_PIN );
    delay_us ( 480 );
void WriteDS1820_Indoor ( void )
    for ( cShiftBit = 1; cShiftBit <= 8; ++cShiftBit )
        delay_us ( 5 );
        output_bit ( INDOOR_PIN, shift_right ( &cDataOut, 1, 0 ) );
        delay_us ( 60 );
        delay_us ( 5 );
void ReadDS1820_Indoor ( void )
    iDataIn = 0;
    for ( cShiftBit = 1; cShiftBit <= 16; ++cShiftBit )
       delay_us ( 5 );
       delay_us ( 5 );
       shift_right ( &iDataIn, 2, input ( INDOOR_PIN ) );
       delay_us ( 55 );
void WaitForConversion_Indoor ( void )
    while ( TRUE )
       delay_us ( 5 );
       delay_us ( 5 );
       if ( input ( INDOOR_PIN ) == 1 )
       delay_us ( 55 );
outdoor.c
///////////// OUTDOOR ///////////////////////
void ResetDS1820_Outdoor( void )
    output_low ( OUTDOOR_PIN );
    delay_us ( 480 );
    output_float ( OUTDOOR_PIN );
    delay_us ( 480 );
void WriteDS1820_Outdoor ( void )
        delay_us ( 5 );
        output_bit ( OUTDOOR_PIN, shift_right ( &cDataOut, 1, 0 ) );
        delay_us ( 60 );
        delay_us ( 5 );
void ReadDS1820_Outdoor ( void )
    iDataIn = 0;
       delay_us ( 5 );
       delay_us ( 5 );
       shift_right ( &iDataIn, 2, input ( OUTDOOR_PIN ) );
       delay_us ( 55 );
void WaitForConversion_Outdoor ( void )
    while ( TRUE )
       delay_us ( 5 );
       delay_us ( 5 );
       if ( input ( OUTDOOR_PIN ) == 1 )
       delay_us ( 55 );
        ResetDS1820_Indoor();
        cDataOut = DS1820_SKIP_ROM;
        WriteDS1820_Indoor();
        cDataOut = DS1820_CONVERT_T;
        WaitForConversion_Indoor();
        cDataOut = DS1820_READ_SCRATCHPAD;
        ReadDS1820_Indoor();
        iTemperature = iDataIn / 2;  // INDOOR Temperature
       // LCD or 7Seg Call routines here
        ResetDS1820_Outdoor();
        WriteDS1820_Outdoor();
        ReadDS1820_Outdoor();
        iTemperature = iDataIn / 2;  // OUTDOOR Temperature
Bytheway,
I am not good with C. How can we use only one routine for both 2 sensors for code space optimization ?
Any suggestions wellcome.
linux123
Stop
PostPosted: Wed Oct 18, 2006 4:46 pm     Reply with quote
Hy, the code stop begin call function, read temp_indoor, but, my code continue load, because call interrupt from serail RX, response, and i add call from SKIP ROM.
Thanks.
linux123
Ok.
PostPosted: Thu Oct 19, 2006 7:04 am     Reply with quote
The code it's ok, but, have insert:
I go job to add precision, because, the code return decimal value.
If anybody help-me, i thanks.
LazBoy
PostPosted: Fri Oct 20, 2006 6:09 am     Reply with quote
I added missed variables.
Yes, it hangs If there is no sensor on communication pin.
You may fix it for your needs.
     INDOOR_SENSOR_NOT_FOUND = FALSE;
    delay_us ( 480 );
    delay_us ( 20 );
           INDOOR_SENSOR_NOT_FOUND = TRUE;
           Break;
    delay_us ( 460 );
