Don't read flash memory PIC18F452
Angelo
PostPosted: Wed Oct 18, 2006 9:19 am     Reply with quote
Help me, i don't know because not read flash memory, how i wanted:
Flash memory after being erased: FF FF FF FF FF FF FF FF
Flash memory after being written: 01 02 03 04 05 06 07 08
in real:
Flash memory after being written: FF FF FF FF FF FF FF FF
This example i took from
http://ccsinfo.com/forum/viewtopic.php?t=28440&start=0&postdays=0&postorder=asc&highlight=write+program+programme+memory&sid=d5adb69c5bbddde1838170e4259da4c5
#include <18F452.h>
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP, NOPROTECT, CPB
#use delay(clock=10000000)
#define ROM_ADDR  0x4000
int8 i;
int8 write_data[8] = {1,2,3,4,5,6,7,8};
int8 read_data[8]  = {0,0,0,0,0,0,0,0};
printf("Flash write size = %u\n\r", getenv("FLASH_WRITE_SIZE"));
printf("\n\r");
// Erase flash memory.
erase_program_eeprom(ROM_ADDR);
// Read flash memory.
read_program_memory(ROM_ADDR, read_data, sizeof(read_data));
// Display it, to show it's erased.
printf("Flash memory after being erased: ");
for(i = 0; i < sizeof(read_data); i++)
    printf("%X ", read_data[i]);
printf("\n\r");
printf("\n\r");
// Now write 8 bytes.
write_program_memory(ROM_ADDR, write_data, sizeof(write_data));
// Read them back.
// Display data read from Flash memory.
printf("Flash memory after being written: ");
printf("\n\r");
printf("\n\r");
PostPosted: Wed Oct 18, 2006 9:38 am     Reply with quote
Hint.
What is the highest program memory address implemented in a 18F452.....
Angelo
PostPosted: Wed Oct 18, 2006 10:12 am     Reply with quote
Excuse me, but I haven't understood that you want to tell by it Sad
It don't working even if to take 0xFF00
PostPosted: Wed Oct 18, 2006 11:10 am     Reply with quote
Are you using an 18F452 ? I ran that code just now, on a PicDem2-Plus
board and it worked OK.
The 18F452 has ROM memory from 0x0000 to 0x7FFF.
The program writes to 8 bytes of ROM memory at 0x4000.
This is in the middle of the available ROM address range.
If you are using 18F242 or 18F442, the program won't work.
Those PICs only have ROM from 0x0000 to 0x3FFF.
What PIC are you using ?
I have another question. Are you doing this on real hardware,
or is this a Proteus project ?
Angelo
PostPosted: Wed Oct 18, 2006 10:37 pm     Reply with quote
Yes i've tested in Proteus, i thought it's will work there?! Sad
But why this doesn't work in Proteus?
PostPosted: Wed Oct 18, 2006 11:17 pm     Reply with quote
Since it works in hardware, I think it's a Proteus problem.
Here's a thread on it in the Proteus forum. One person says it
doesn't work. Another one says it does.
http://support.labcenter.co.uk/forum/viewtopic.php?t=231&highlight=18f452
I suggest that you ask a question on that thread. Tell them your
version of Proteus and explain that it works OK in hardware.
Ask why doesn't it work with Proteus.
Here's the main page for the Proteus VSM forum:
http://support.labcenter.co.uk/forum/viewforum.php?f=9
rberek
PostPosted: Thu Oct 19, 2006 5:48 am     Reply with quote
For unlicensed users of Proteus, the program is designed to work incorrectly and make life difficult for unregistered users. I've helped out a few people on it, and the root cause of the problem was they were using unregistered copies.
If you are using the licensed version, then contact Labcenter with your problem. However, I've simulated reading and writing from flash memory many times with a PIC18F452 in the past, and it simulates fine.
Angelo
PostPosted: Thu Oct 19, 2006 8:56 am     Reply with quote
Thank you
