jruibarroso
What comands may we use with printf on RS232 ? |
Posted: Mon Oct 16, 2006 1:20 pm |
What comands may we use with printf RS232 ?
i know that \n goes to the next line, on LCDs results fine but on RS232 goes to the next collumn on the next line
waht is the meaning of \r ?
thank you |
Posted: Mon Oct 16, 2006 2:22 pm |
\n, is 'line feed', or 'newline'. Depending on the actual 'terminal' being used to display the character, this may perform a line feed, or a carriage return may automatically be performed as well (\r).
In Hyperterminal, this is controlled by 'file', 'properties', 'settings', 'ASCII setup', and the tickbox 'append line feeds to incoming line ends'. The LCD always does this.
